    Solved BLtouch is triggering but not stopping axis from moving
    • mikea702
      mikea702 last edited by
      Hey all,
      I just made the transition from Marlin finally and its been pretty easy going besides this one last issue which has been driving me absolutely crazy trying to figure out...
      On power on, the BLTouch does its self test just like in Marlin.
      The light on the probe goes off with the pin being down and when the pin is pushed in, it retracts and the light comes on as expected.
      M401 & M402 respond as intended. I have macros created to test the probes functionality and all of those also respond as intended.
      When I try to home Z, when the probe is triggered it retracts but it does not stop the axis from moving down. Instead it just deploys the pin again.
      I have reviewed this: https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
      I do have the BLTouch classsic and have not added the resistor but it doesn't sound like that is not the issue?
      My issue must be in my config, right?? I have it hooked up to heater 7 as seen below:
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P4 S1 ; Drive 4 goes forwards
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X80.00 Y40.00 Z400.00 E415.00:415.00 ; Set steps per mm
      M566 X600.00 Y600.00 Z23.40 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z240.00 E1800.00:1800.00 ; Set maximum speeds (mm/min)
      M201 X550.00 Y550.00 Z100.00 E250.00:250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 S1 ; Set axis min
      M208 X295 Y277 Z295 S0 ; Set axis max
      M574 X1 Y1 S0 ; Set active low endstops
      M574 Z1 S2 ; Set Z endstops controlled by probe
      M307 H7 A-1 C-1 D-1 ; Disable heater 7 on PWM channel for BLTouch
      M558 P9 H5 F500 T9000 A3 ; Set Z probe type to bltouch and the dive height + speeds, try up to 3 times for each point for accuracy
      G31 P25 X9 Y-52.7 Z0.0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:240 Y15:240 S20 ; Define mesh grid
      M305 P0 T10000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M106 P0 S0 H-1 ; Set fan 1 value, default speed 0%
      M106 P2 S0 H-1 ; Set fan 2 value, default speed 0%
      M563 P0 S"Left Nozzle" D0 H1 ; Define tool 0
      G10 P0 X9 Y0 Z0 ; Set tool 0 axis offsets
      M563 P1 S"Right Nozzle" D1 H2 ; Define tool 1
      G10 P1 X-9 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
        How do you have it wired up?
        What does your homeall.g and Homez.g macros look like?
        Double check the wiring for continuity. Damaged crimps are very very common.
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
        Use the method described here to test it using G30 from the console.
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          Phaedrux Moderator @mikea702 last edited by
          @mikea702 said in BLtouch is triggering but not stopping axis from moving:
          M558 P9 H5 F500
          Unrelated, but you'll get more accurate probe results out of it if you slow down your probing speed to F100 or so. If this makes homing unbearable slow you can modify the homing macro to probe once quickly to get the probe to the bed fast, and then probe again at a slower rate for accuracy.
          mikea702 1 Reply Last reply Reply Quote 0
          • mikea702
            mikea702 @Phaedrux last edited by
            Testing it per the dynamic test described in the linked article, it failed to stop the Z axis when triggered.
            As for the wiring I mainly followed this walk-through: https://betrue3d.dk/bltouch-on-duet-wifi-duetreprapfirmware/
            @phaedrux said in BLtouch is triggering but not stopping axis from moving:
            M558 P9 H5 F500
            Good advice, I'll probably end up doing a fast probe followed by a slower one as advised.. just haven't got that far yet 😅
              Check the wiring. Especially the Z probe connector.
              • mikea702
                Sorry, forgot to send my homeall.g and Homez.g files but reversing the probe wires worked! I would have never guessed that. Thank you so much!
                  Glad it's working.
