    Up Mini 2 - what to use button and LEDs for?
    • A Former User
      So I'm in the progress of converting an Tiertime Up Mini 2 to Duet 2 Maestro, or liberating it I guess we could say.
      Got the motion sorted, waiting for my PT100 board. Loving the resources available for this ecosystem!
      But as the title suggests, the machine as a button on the side, which also have a red and a blue LED. Currently it has the following fuctions:
      • LEDs flash...
      • short press button toggles case LED
      • long press button puts machine to sleep.
      Long press won't be needed as the Duet will not be needing a sleep function. LEDs will stay on, so question is:
      Is there any usefull things these things could be used for? E-stop is the only thing that comes to mind, but I fear its too accessible for that, and would rather add a mushroom style switch for that.
      Worth noting the LCD in front will be a 4.3" Panel Due which fits almost perfectly.
      • oliof
        oliof last edited by
        You could use the button as an external trigger (M581/M582 on the wiki for documentation of setting up and using triggers), for example for an emergency shutoff button. But that will probably be limited to a single function and not include the LEDs.
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
          Pause button, perhaps?
          • A Former User
            Pause while printing makes more sense than e-stop given less consequence if accidentally activeated; I guess I'll get more a feel for what the Due Panel doesn't do for me once I've used it for a while.
            But all in all I think whatever the button can do, the panel can also do, just wondering if people actually have physical buttons besides e-stop, and what the use case is.
            • oliof
              The e-stop idea was exactly for the cases where I wouldn't want to deal with the iffiness of a touch screen where the e-stop might or might not be visible (I don't have a PanelDue so I don't know if it does, I'd expect it though). But a pause button is a decent alternative IMHO.
              • A Former User
                I think I'll add something that looks like an e-stop instead of using the inconspicuous switch on the side; or if e-stop is something one could resume from if accidentally triggered thats not the end of the world after all - but I feel e-stop should look like e-stop.
                I guess there is also the reed or hall sensor in the front door that could be a pause button. Still lots to figure out, love it!
