Job Status don´t work
@dc42 - the wifi connection has been very reliable since I put Google Wifi points around the house and one in the garage. Before that it would drop regularly. But that was the beginning of the year and I had this issue before then. Attached are my config files. Hopefully you can spot something there? Should I blow away the web server files on the SD and recreate the folder from the latest zip resources?2_1557270693645_config.g 1_1557270693645_StartPrint.g 0_1557270693645_EndPrint.g
@jgrouse said in Job Status don´t work:
Replacing the DWC files in the /www folder with the latest version couldn't hurt. Perhaps a file has become corrupted or unreadable or something.
@phaedrux said in Job Status don´t work:
You could also upgrade DuetWiFiServer to the 1.23 release (instead of the beta that you are currently using) and main firmware to 2.03RC1.
