    Printer tuning - what to check and what order
    • jay_s_uk
      jay_s_uk last edited by
      I've been away from printing for quite a while and I'm relatively rusty when it comes to printer tuning etc.
      I've recently purchased an anycubic kossel like ear plus and have converted it over to a duet Ethernet. I can print and the quality is similar to what I was getting with the old controller.
      I now want to go through tweaking each part of the printer.
      Does anyone have any recommendations as to what to tweak and in what order?
      Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
        My suggestions:
        • Delta at calibration is important, if you haven't already done it.
        • Extruder steps/mm calibration, unless you know the exact value from using your previous firmware.
        • Temperature tests. Different firmwares handle thermistors in different ways, so the actual temperature for a given set temperature may be a few degrees different.
        • For Bowden systems especially, pressure advance helps with print quality.
        • When you've done everything else, if you want to print really fast, you may wish to calibrate nonlinear extrusion.
        • jay_s_uk
          Great, thanks
