    Midi to M300
    • paboman
      paboman last edited by
      is there a way to convert midi to Gcode using M300 command ?
        Kind of... https://www.makeanything.design/3dprintermusic
        paboman 1 Reply Last reply Reply Quote 0
        • paboman
          paboman @Phaedrux last edited by
          @phaedrux THX!
          • paboman
            paboman last edited by paboman
            I have added this to config.g but it does not play on machine startup while the same command in a macro works.
            ; STARTUP TUNE
            M300 S3000 P200
            G4 P200
            M300 S3520 P200
            G4 P200
            M300 S1300 P400
            If the machine is already booted up and I hit emergency stop then the tune is played correctly
              I've found that the Duet needs some extra time at first bootup to finish doing what it's doing before the tone commands will execute properly.
              This is what I have and it seems to work fairly well most of the time. Though I think I need to make the pauses longer now. Recent firmwares seem to behave a little differently.
              ; BLTOUCH PREP
              G4 S1
              M280 P3 S160 I1 		; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
              G4 S1
              M402				; Retract probe just in case it's down
              ; STARTUP TUNE
              M400
              G4 S1
              M300 P200 S1975.53
              G4 P201
              M300 P200 S2217.46
              G4 P201
              M300 P200 S1975.53
              G4 P201
              M300 P200 S2793.83
              G4 P201
              M300 P200 S2489.02
              G4 P201
              M300 P200 S2217.46
              G4 P201
              M300 P200 S2489.02
              G4 P201
              M300 P200 S2959.96
              G4 P201
              M300 P300 S3520.00
              G4 S1
              M400
