    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.2k
    • hestiahuangundefined
      hestiahuang @chrishamm
      @chrishamm said in Duet Web Control 2.0.0-RC6:
      So hopefully this one is really the last RC before the actual release. You can get it here: https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.0-RC6
      Here once again the changelog:
      Updated NodeJs components (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
      Changed click behaviour of file list items to be activated on a single click again
      Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
      Print information is no longer cleared when a print finishes
      Simplified file list reset when the connection is interrupted
      Print+Simulate options are hidden when a job file is being processed
      Escape closes the text editor again
      Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
      Minor other changes
      Bug fix: Notification when editing a large file was not displayed during download
      Bug fix: Macro list did not return to the root directory when the connection was interrupted
      Bug fix: Warm-up time was not displayed
      Bug fix: Selected tool was no longer highlighted when the light theme was selected
      Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
      Let me know if any other issues come up.
      I want to report an issue, after I uploaded the config files. It doesn't prompt up and ask for the restart the firmware. However it can on version 1.x...
      • jv43undefined
        jv43 @chrishamm
        @chrishamm
        Just another little bug report:
        1. the visibility of text when using dark mode is really poor, maybe its just cause im partly colorblind, but another shade of blue would be greatly appreciated
          text visibility
        2. I love being able to select which fans are shown but after selecting my LED (configured as Fan 2, Fan0 can be selected an deselected and it works fine)
          fan slider
        3. any reason there is no option in DWC2 to show the heightmap? found it quite usefull to get my bed as flat as possible
        Edit regarding 3.: nvm i found the heightmap tab, really like that implementation!
        • totalosundefined
          totalos
          Hello.
          I think that on Dashboard/Extrusion Control
          "Feed amount in mm" and "Feedrate in mm/s: " default data will be 5 and 5.
          Now is 100 and 60 - in my opinion it is not safe and not good.
          Can I save other default value in RC6?
          jv43undefined 1 Reply Last reply Reply Quote 1
          • jv43undefined
            jv43 @totalos
            @totalos
            I second that! It really should be 5 and 5 at default, better to extrude too little and too slow than too much and too fast.
