    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.2k
    • whosrdaddyundefined
      whosrdaddy @frank26080115
      @frank26080115 : yep he did, and being a halfass towards others isn't going to help him...
      • robmundefined
        robm
        Sorry I am a bit late to the party but here are some comments/issues:
        • The active temperature drop-down menu was truncating the values until I did a 'command -' to zoom out one step. This is fine but there was still lots of space around the elements, and more if I dragged the window wider.
        • I don't have an ATX power supply configured, can I make that control go away?
        This is on a 2012 MacBook Pro retina, running Firefox.
        Otherwise looks very nice. I thought the ability to edit the drop-down list of g-codes on the top bar had gone away, but I worked it out and prefer this newer implementation.
        Very happy to see the continued development.
        Rob.
        • wilrikerundefined
          wilriker
          @chrishamm I found another issue. I have a macro that works a bit like G32 with no probe, i.e. it goes to several points and then presents the jog dials for Z.
          In previous versions it was only possible to press reach jog button once but that has been fixed.
          Now I have a new issue where the dialog is only shown at the first point. If I click on OK there the head moves to the next point but no dialog is shown. Switching to DWC1 immediately presents the dialog and all following. I did not try to reload DWC2 to see what happens, though.
          Manuel
          My Tool Collection
          • chrishammundefined
            chrishamm administrators @wilriker
            @wilriker said in Duet Web Control 2.0.0-RC6:
            That bug was related to the message boxes in general and it has been fixed in RC7.
            Duet software engineer
            Catalin_ROundefined 1 Reply Last reply Reply Quote 1
            • Catalin_ROundefined
              Catalin_RO @chrishamm
              @chrishamm When will there be a RC7 package available for download? So far I can only find up to RC6 ZIP files.
                A Former User
                @chrishamm
                looks good as far as I can tell! (took me a while to copy it to the sd-card - 🙂 )
                1 feature-request for people with moving-plate instead of moving-head, to make the symbol of the baby steps "ambidextrous" for both parties: dc42 already included it in the latest build for the panel due (https://forum.duet3d.com/topic/10061/paneldue-firmware-1-23-now-available/8) - it are two arrows either opposing each other for closer together - or two arrows pointing away from each other for spreading apart...
                All the best! Nice work!
                -> THANKS FOR THE TIMESTAMPS on the diagramm(s)
                • hestiahuangundefined
                  hestiahuang @chrishamm
                  @chrishamm said in Duet Web Control 2.0.0-RC6:
                  So hopefully this one is really the last RC before the actual release. You can get it here: https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.0-RC6
                  Here once again the changelog:
                  Updated NodeJs components (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                  Changed click behaviour of file list items to be activated on a single click again
                  Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                  Print information is no longer cleared when a print finishes
                  Simplified file list reset when the connection is interrupted
                  Print+Simulate options are hidden when a job file is being processed
                  Escape closes the text editor again
                  Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                  Minor other changes
                  Bug fix: Notification when editing a large file was not displayed during download
                  Bug fix: Macro list did not return to the root directory when the connection was interrupted
                  Bug fix: Warm-up time was not displayed
                  Bug fix: Selected tool was no longer highlighted when the light theme was selected
                  Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                  Let me know if any other issues come up.
                  I want to report an issue, after I uploaded the config files. It doesn't prompt up and ask for the restart the firmware. However it can on version 1.x...
                  • jv43undefined
                    jv43 @chrishamm
                    @chrishamm
                    Just another little bug report:
                    1. the visibility of text when using dark mode is really poor, maybe its just cause im partly colorblind, but another shade of blue would be greatly appreciated
                      text visibility
                    2. I love being able to select which fans are shown but after selecting my LED (configured as Fan 2, Fan0 can be selected an deselected and it works fine)
                      fan slider
                    3. any reason there is no option in DWC2 to show the heightmap? found it quite usefull to get my bed as flat as possible
                    Edit regarding 3.: nvm i found the heightmap tab, really like that implementation!
                    • totalosundefined
                      totalos
                      Hello.
                      I think that on Dashboard/Extrusion Control
                      "Feed amount in mm" and "Feedrate in mm/s: " default data will be 5 and 5.
                      Now is 100 and 60 - in my opinion it is not safe and not good.
                      Can I save other default value in RC6?
                      jv43undefined 1 Reply Last reply Reply Quote 1
                      • jv43undefined
                        jv43 @totalos
                        @totalos
                        I second that! It really should be 5 and 5 at default, better to extrude too little and too slow than too much and too fast.
