    duex5 not working?
    866
    • tenjin
      tenjin last edited by
      help!
      my Duex5 seems to not be working well
      i have been able to use PWM5 for my bltouch, that part works, but the motors are not working
      here is the config that does not drive the motors: 0_1551926112738_config -- Does not work.g
      here is a config that drives the motors using driver 2 and 4 0_1551926117314_config -- works.g
      the truly concerning part for me is the lack of seeing the duex in M115
      7:36:21 PM M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03beta2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-02-16b1
      output of m122 with every thing but the BL touch on the duet:
      7:37:29 PM=== Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta2 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MS4-6JTDA-3S06S-T8ZHA
      Used output buffers: 3 of 20 (15 max)
      Static ram: 25532
      Dynamic ram: 91720 of which 0 recycled
      Exception stack ram used: 360
      Never used ram: 13460
      Tasks: NETWORK(ready,544) HEAT(blocked,1236) MAIN(running,3784) IDLE(ready,196)
      Owned mutexes:
      Last reset 00:05:55 ago, cause: software
      Last software reset at 2019-03-06 19:31, reason: User, spinning module GCodes, available RAM 13492 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 37.7, current 38.0, max 38.1
      Supply voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 1291325566
      Slowest loop: 1.11ms; fastest: 0.08ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 5, completed moves: 5
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 202.16ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.23beta1
        WiFi MAC address b4:e6:2d:53:16:0e
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 22736
        WiFi IP address 10.0.1.20
        WiFi signal strength -51dBm, reconnections 0, sleep mode modem
      and with motor drivers 8 and 9
      M122
      Used output buffers: 3 of 20 (6 max)
      Static ram: 25532
      Exception stack ram used: 328
      Never used ram: 13492
      Tasks: NETWORK(ready,544) HEAT(blocked,1236) MAIN(running,3792) IDLE(ready,196)
      Owned mutexes:
      Last reset 00:00:15 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 13460 bytes (slot 0)
      Error status: 0
      MCU temperature: min 37.9, current 38.6, max 38.7
      Date/time: 2019-03-06 19:38:52
      Cache data hit count 44553741
      Slowest loop: 3.67ms; fastest: 0.07ms
      Scheduled moves: 0, completed moves: 0
      Segments left: 0
      === Network ===
      Slowest loop: 15.54ms; fastest: 0.00ms
      • WiFi -
        WiFi flash size 4194304, free heap 25488
        WiFi signal strength -50dBm, reconnections 0, sleep mode modem
      • tenjin
        I presume by the lack of input i either didnt post enough information, or no one has a clue?
          It may take a day or two before someone who has a good answer comes along.
          One thing I can think of off the top of my head. Do you have the grounding wiring setup as described in the duex wiki? I'm not a duex expert.
          • tenjin
            yes, i have a solid core wire, as short as humanly possible, with the duet / duex side by side for testing
            • gavatron3000
              gavatron3000 last edited by
              the ribbon cable is connected correctly also? M122 for me shows the duex. And the cross sectional area of your supply to the duex is at least 2.5mm²?
              • deckingman
                deckingman @tenjin last edited by
                @tenjin The Duex5 should show up on the "Setting - general" page of DWC next to "Firmware Electronics" like this:
                Firmware Electronics: Duet Ethernet 1.0 or 1.01 + DueX5
                And it should be reported by M115 like this:
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03beta2 ELECTRONICS: Duet Ethernet 1.0 or 1.01 + DueX5 FIRMWARE_DATE: 2019-02-16b1
                So it's not your configuration. It's either the wiring, or a faulty ribbon cable or connector, or a faulty board I guess. What happens if you connect an end stop to one of the Duex5 end stop connectors? Does the associated LED light up and change state if you trigger the switch?
                tenjin 1 Reply Last reply Reply Quote 0
                • tenjin
                  tenjin @deckingman last edited by
                  @deckingman
                  I will double check the endstop...
                  As to the guage of the wire, i do not recall the guage off hand, i can confirm when i get home
                  its thicker copper core than standard house wiring though, really beefy, probably 14, if not 12 ga.
                  output from settings -> general:
                  Firmware Version: 2.03beta2 (2019-02-16b1)
                  WiFi Server Version: 1.23beta1
                  Web Interface Version: 1.22.6
                  • deckingman
                    @tenjin I doubt it's the wire gauge. The board just isn't being "seen" at all.
                    I hesitate to ask this but you have got them wired + to + and _ to _ haven't you? It's just that the boards are designed to fit back to back so the terminals are reversed on the Duex compared to the Duet main board so it would be an easy mistake to make.
                    • tenjin
                      tenjin @deckingman last edited by tenjin
                      @deckingman
                      don't hesitate, I'm not immune to mistakes 😉
                      in this instance though yes, i have them correct, reverse polarity as compared to the duet due to the design for back to back fitment , if there is any thing working IT and as a network engineer has taught me, check, recheck, check again, and recheck one more time before you plug that thing in, mistakes are bad 😉
                      when i get home i can take a picture for more clarification if needed.
                      • deckingman
                        @tenjin No I believe you. Personally I'm leaning towards it being a fault with the ribbon cable or maybe the board itself, but I'm just an end user like you. Maybe one of the Duet team will step in with some better ideas.
                        • tenjin
                          under this chip
                          are these solder pads
                          wonder if there is just a bad solder job causing it?
                          • tenjin
                            i see you are rather knowledgeable on the duet / duex products, Have you got any input on this one? im a bit at a loss where to go.
                            Kind of starting to regret my decisions to go this route. -- expensive learning experience so far.
                            recap: hardware: duet wifi + duex 5 + paneldue 7i
                            currently i have all fans working as intended, 3 PWM fans on the Duet, one thermostatically controlled hotend cooler
                            one tool fan
                            one thermostatically controlled MCU fan
                            x and y are in original intended motor drivers and work fine
                            z i want on drivers 8 and 9, eventually will be 7 8 9 when i finish my coreXY with tripple z screws.
                            BL touch is using PWM 5 on the Duex and prob connector on duet, as described here: https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                            and surprizingly it actually works, while i cannot get the motor drivers on the duex to work
                            setting the motor drivers for z to 2:4 works fine.
                            also noticed last night, one of the endstop LEDs on the duex is permanantly on but super dim, i want to say it was stop 5?
                              Looks like a bad DueX5, bad ribbon cable, or just possibly a bad Duet. Please ask your supplier to replace the DueX5 and ribbon cable.
                              • tenjin
                                tenjin @dc42 last edited by
                                Not shocked at the suspicion of a failed duex, it was mine from the get go, supplier asked that i open a thread and get a response from you guys to validate the claim for RMA
                                thanks for reviewing and confirming.
                                  dc42 administrators @tenjin last edited by
                                  @tenjin, I'm sorry it took a day to respond to your post. I'm very busy with getting Duet 3 working and other stuff right now, so I'm not reading the forum as often as usual.
                                  tenjin 1 Reply Last reply Reply Quote 1
                                  • tenjin
                                    What, you mean your not my dedicated servant??!!!
                                    no worries, absolutely appreciate your help
                                    now to get my Duex5 RMA'd
                                    • fcwilt
                                      fcwilt last edited by
                                      While I don't have an specific answer for you regarding your current problem I can say the combo should work fine.
                                      I have five printers equipped with the Duet WiFi/Duex 5 combo and have had not issues.
                                      • tenjin
                                        i just realized ... thats your name silk screened on this duex5 isnt it ....
                                        thats freaking amazing customer service if the lead product engineer is trouble shooting things for customers.
                                        • tony449777
                                          tony449777 last edited by
                                          I’m having the same problem. I have 3 z motors connected to my Duex5 board and a BL touch in PWM1 or E2 heater. The board does not show up when I use M115, however when I Turn the printer on the BL touch probe cycles.
                                          When I home all, the heater light for the two lights up showing that it is activating the probe. How can the board not be showing up but also still activating the probe?
                                          tony449777 1 Reply Last reply Reply Quote 0
                                          • tony449777
                                            tony449777 @tony449777 last edited by
                                            I also forgot to mention I finished building this printer two weeks ago, and have been using it for a week plus and everything has worked great.
                                              Phaedrux Moderator @tony449777 last edited by
                                              @tony449777 Please start a new thread with your issue. Include all the info described here: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help/11
