    Firmware Modification ROM file size exceeded
    • rinturaj
      rinturaj last edited by
      Hi everyone, I have a duet3d 7i LCD screen, I want to modify the UI for our new 3d printer.so we decided to use our own custom icons. while converting the BMP icons to c array, we getting uint16_t format with "bmp2c.exe" converter. so we tried with so other software but those array images are not displaying properly.
      uint16_t array icons are working fine but when we putting more icon arrays in the project, the build size is exceeding.
      if uint8_t is supporting in duet3d 7i, how could I generate uint8_t image array?
      NB: our images having black and white colors only.
      NB: array format used -
      extern const uint8_t test[] = { 60, 60,
      0xff, 0xff, 0xff, 0xff, 0xff, 0xf...............}
      NB: uint16_t working fine .
        The bmp2c program needs to be updated to generate uint8_t values from a 256-colour image. We originally used uint16_t values representing the RGB values in 5-6-5 format. Then I accepted a pull request to use 8-bit values and a pallette instead. But bmp2c was not updated.
