    Choosing a suitable power supply
    23
    2.5k
    • pedromelimundefined
      pedromelim @snoozer
      @snoozer im gonna use a spare e3d v6.1 i think...the ones used on the original prusa...got a spare one hehe
      After much thought and some more research, i decided to go 24v instead of mains (220v).
      For both safety and the simplicity of everything.
      The RSP-500-24 will do just fine, as i found that is used on the lulzbot taz 6wich used a silicone heated bed rated at 360w.
      The heated bed will probably be the same as the taz 6.
      Difference in price from one way to the other is around 25€ and i much prefer paying a bit extra for the simplicity of the system.
      Tks everyone for the input on the matter.
      snoozerundefined 1 Reply Last reply Reply Quote 0
      • snoozerundefined
        snoozer @pedromelim
        @pedromelim
        After much reading and a bunch of good an plausible advice I also give a silicone heater under a substantial aluminium plate a go. I stay with 230 AC, I am qualified electrician (in a former life) so no worries about mains. Did you order the V-Core including the printed parts ? the hotend mount is designed for a v6 I think. I have spend all last WE to make a Titan Aero mount, only done it in PLA with little infill as test. Still don't have the kit to put it on actually. I like to have it detachable and keep the belt tensioner attached. I split the mount. Intend to be able to manually change between hotends and also service it easy. Maybe able to use a laser as well.......... that's for future.
        Jan
        Regards Jan
        My Printers:
        #1 Prusa i3 MK3 kit all stock (Retired)
        #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
        My Experiments:
        https://www.thingiverse.com/snoozer17/designs
        • PuterProundefined
          PuterPro
          @snoozer said in Choosing a suitable power supply:
          I did a rework of this mount, in Fusion 360: E3D V6 Hinged Extruder Bracket & Clamp for my little Monoprice Select v2. It's pretty kludgy so I didn't post my rework, but I have all the wires on plugs and can change the v6 clone on it in about 30 seconds. (Went with genuine v6 Gold for my CR-10S)
          Kinda cool to have a hinge.
          @pedromelim - Good luck with your project, keep us posted!
