Solved Need Help Duet2 WIFI and BLTouch
Hey guys having an issue I cant seem to figure out. BLTouch on my CoreXY decided to do it own thing today and I cant seem to figure out why. I printed just yesterday and it was fine. The only thing that changed was that I swapped to a V6. My config, homeall and homez are attached.
Notes :
It deploys and retracts the pin on command.
Alarm is not being triggered on the BLTouch.
Home all homes X and Y but states Zprobe already triggered at start of homing move.
Zprobe is staying at 1000 with probe deployed and retracted.Anyone got any suggestions?
CONGFIG
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P3 S1 ; Drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E442.00 ; Set steps per mm
M566 X1000.00 Y1000.00 Z800.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z900.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z1000.00 E250.00 ; Set accelerations (mm/s^2)
M906 X1300.00 Y1300.00 Z1300.00 E1300.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
G31 X-40.30 Y-15.77 Z1.28 P25 ; Set Z probe trigger value, offset and trigger height
M557 X35:215 Y30:195 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
HOMEALL
G91 ; relative positioning
M98 Pdeployprobe.g ; deploy mechanical Z probe
G1 S1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-335 ; home X axis
G1 S1 Y-335 ; home Y axis
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y-335 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X180 Y180 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningM98 Pretractprobe.g ; retract mechanical Z probe
HOMEZ
G1 X180 Y180 F6000 ; go to first probe point
G1 Z10 F6000 ; rapidly move the Z axis to z=10 -
Which firmware version are you running?
@smk2019 said in Need Help Duet2 WIFI and BLTouch:
Did a wire get loosened?
What happens when you go through the steps here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
M98 Pretractprobe.g ; retract mechanical Z probeThose shouldn't be necessary anymore. The Duet will take care of deploying and retracting as needed.
2.02 No wires are loose all of them are connected and BLTouch is responding correctly. Thats the reason it is throwing me through a loop. I cant Run a homeall sequence. it runs X and Y but not Z
Check the white wire. That's the signal wire for triggering. If it's saying already triggered at the start of probing move that's where I would check first.
If the last thing you worked on was you changed to a V6 that seems like a likely time for something to have gotten bumped.
@phaedrux That got it. it was such a small bend that to the naked eye it was unnoticeable. I had to get the magnifying lamp out and clamp it to the table to really look at it and it had a small bend. I appreciate it and thank you for your help. I was getting ready to just turn off the z stop and print like that tonight.
