    Wishlist: display x,y,z in the Move control
    PanelDue
    • zapta
      zapta last edited by
      In the Move control on the PanelDue (the one that allows to move x,y,x in 0.5, 5, 50, ... increments), please display also the current x,y,z.
      I use this panel for various testing often need to exit that panel to view the current x,y,z.
      Thanks.
        I've moved this request to the PanelDue section of the forum.
        • resam
          resam last edited by
          This has been requested multiple times already on the forums.
          I implemented this feature and sent a pull request: https://github.com/dc42/PanelDueFirmware/pull/43
          Keep in mind that this problem can only be solved for the most common printers. Printers with additional axis or non-standard configs might not have enough space on the screen to display the additional controls.
          Kriechi created this issue in dc42/PanelDueFirmware
          closed add axis coordinates to MovePopup and PrintTab #43
          dragonn zapta 2 Replies Last reply Reply Quote 0
          • dragonn
            dragonn @resam last edited by dragonn
            @resam Maybe moving the extra axis to a separate menu would be a good solution even for the users with extra axis? I think even when you have extra axis most time you are interested in the basic three.
            This would allow even to display the basic three axis like in pronterface (with I think is more user friendly)
            • zapta
              @dragonn said in Wishlist: display x,y,z in the Move control:
              It would be nice to have UP on the screen moves the bed up (which decreases Z in my case). Having to click -50 on the LEFT side of screen to move the bed UP over challenges my brain 😉
              • zapta
                zapta @resam last edited by
                @resam said in Wishlist: display x,y,z in the Move control:
                I looked briefly at your code. It seems to address the case of no space on the screen with the (MaxAxis < 5) condition, so should help vast majority of users and will not affect the rest.
