    G32 does not work " RESOLVED "
    Firmware installation
    • synergy41
      synergy41 last edited by synergy41
      Hello everyone,
      I was forced to reinstall my duet wifi on my delta little monster because it did not want to make a home in Z0 and Y0.
      Now everything is in order except that I have a problem when I run a G32.
      My delta feels all the points as expected but it does not show me any results when I enter orders M665 and M666.
      So I think the calibration is not done properly.
      I enclose a screenshot and the files on my card,
      thank you
      0_1552840085141_bed.g
      0_1552840100182_config-override.g
      0_1552840111116_config.g
      0_1552840119353_deployprobe.g
      0_1552840136378_homedelta.g
      0_1552840145873_pause.g
      0_1552840158574_resume.g
      0_1552840170510_retractprobe.g
      0_1552840179714_sleep.g
      0_1552840199452_stop.g
      0_1552840208057_tfree0.g
      0_1552840222612_tpost0.g
      0_1552840230869_tpre0.g
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
      Duet WiFi Server Version: 1.26
      Duet Web Control 2.1.7
      Simplify 3d Ver 4.1.2
      Cura 4.6.1
      • synergy41
        no one has an idea of ​​the problem?
        I LOVE MY DUET WIFI
        Cura 4.6.1
        • themelle
          themelle last edited by
          As far as I can tell you your bed.g is missing a G30 command with the appropriate S-Parameter to perform the desired calibration calculation.
          See https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe and https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed.
          Also, you may need to include a M501 command a the end of your config.g to enable execution of config-override.g.
          dc42 1 Reply Last reply Reply Quote 2
          • synergy41
            Okay, I'm looking tonight when I get home from work.
            I LOVE MY DUET WIFI
            Cura 4.6.1
              dc42 administrators @themelle last edited by dc42
              @themelle said in G32 does not work:
              Exactly that. The last G30 command in bed.g needs the S parameter, normally S6 or S8 to calibrate a delta.
              • synergy41
                Thanks to you 2, that was it.
                I LOVE MY DUET WIFI
                Cura 4.6.1
