    duet 2 wifi ona ctc dual help plz
    3279
    • twistedechos
      twistedechos last edited by
      i just installed a duet 2 wifi on my ctc and can not get it to work i configed the gcode and all but im not sure if i did it right if anyone can help me plz and thank you guys.
        Gonna need way more information.
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        • twistedechos
          o im sorry its a corexy the only change i made to the printer are the duet 2 wifi and i put dual e3 extruders on it so it still uses all the stock spects on the ctc dual. i think it is a clone of the replicator dual. here are my g-code files that i configurated. i dont think they are right though when i go on the duet test it only shows 1 extruder and wont move anything but that extruder.
          [16_1552921114458_tpre1.g](Uploading 100%) [15_1552921114458_tpre0.g](Uploading 100%) [14_1552921114458_tpost1.g](Uploading 100%) [13_1552921114458_tpost0.g](Uploading 100%) [12_1552921114458_tfree1.g](Uploading 100%) [11_1552921114458_tfree0.g](Uploading 100%) [10_1552921114458_stop.g](Uploading 100%) [9_1552921114458_sleep.g](Uploading 100%) [8_1552921114457_resume.g](Uploading 100%) [7_1552921114457_pause.g](Uploading 100%) [6_1552921114457_homez.g](Uploading 100%) [5_1552921114457_homey.g](Uploading 100%) [4_1552921114457_homex.g](Uploading 100%) [3_1552921114457_homeall.g](Uploading 100%) [2_1552921114457_config.json](Uploading 100%) [1_1552921114457_config.g](Uploading 100%) [0_1552921114457_bed.g](Uploading 100%)
          • twistedechos
            https://www.amazon.com/CTC-Printer-Extruder-Nozzle-build/dp/B00URFFGQG this is the printer as i bought it i am still new to all this stuff if you need any thing else let me know please and thank you guys for the help
              dc42 administrators @twistedechos last edited by
              @twistedechos said in duet 2 wifi ona ctc dual help plz:
              For some reason, your file uploads haven't worked. Maybe there is a limit to how many you can upload at once. Please try again, starting with just config.g and the homing files.
              Also please explain what you mean by "can not get it to work". What commands did you send, what did you expect to happen, and what actually happened?
              • twistedechos
                when i try to home any of the axis it give me error g28 x g28 y and g28 z here are the files also. the printer will not do anything but move the extruter stepper it will not even heat the bed or the extruters. i am new to all this i dont know much about gcode at all. if you need any other files let me know thank you again for the help.
                3_1552925130018_homez.g 2_1552925130018_homey.g 1_1552925130018_homex.g 0_1552925130018_config.g
                  Phaedrux Moderator @twistedechos last edited by
                  What is the error?
                  • twistedechos
                    it is g28
                      but what does the error message say?
                      • twistedechos
                        sorry it says g28 homing failed
                        • twistedechos
                          i should specify that it is under the duettest interface idk where else to look for the erorrs
                            dc42 administrators @twistedechos last edited by dc42
                            Is that the only error message? If so, that indicates that you sent a G28 command to home the printer, but the commands in your homing file didn't cause the motor to move so as to trigger your homing switch.
                            Have you tested the motors individually? To do that, first send command G91 to select relative coordinates. Then send G1 s2 commands to command the motors. For example, G1 S2 X50 commands the X motor to move 50mm in the +X direction. Command G1 S2 X-50 commands it to move 50mm in the -X direction.
                              I think you may benefit from this guide: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
                              • twistedechos
                                i get m120
                                g91
                                g1 x-100 f6000
                                m121
                                error g0/g1 insufficient axes homed
                                the only thing it will let me do is click the retract and extrude extruder 1
                                if i can up load a video i can show you everything i think i might need to redo the reprap config or something but i dont know my min and max axis settings
                                  Can you post your homeall as well?
                                  This happens when trying to move an axis before it is homed. Usually this is when the Z axis is lifted a bit to give clearance for homing X and Y.
                                  From the FAQ: https://duet3d.dozuki.com/Wiki/FAQ
                                  I get this error message: "Error: G0/G1: insufficient axes homed"
                                  Recent firmware versions do not allow axes to be moved before they have been homed. The only movements allows are homing moves (G1 moves with S1 or H1 parameter) and individual motor moves (G1 moves with S2 or H2 parameter). So any Z movements that your homing files make before Z is homed should use the S2 parameter. Alternatively, add M564 H0 to config.g to allow axis movement before homing.
                                  • twistedechos
                                    This post is deleted!
                                    • twistedechos
                                      it wont let me upload the vid
                                        Might need to use Dropbox or YouTube
                                        • twistedechos
                                          https://youtu.be/ZGwYuOgqCJM here it is if you need any other info from me let me know in the mean time im going to read up on the links you sent me
                                          • twistedechos
                                            i wonder if anyone has the original gcode files for the ctc my old board fried if i could get those i should just be able to upload them to the board right?
                                            • twistedechos
                                              https://3dprinting.com/pricewatch/3d-printer/ctc-bizer/?fbclid=IwAR1yXJLIZn4f_zbPCmQrPTTxfIqpmlKQ0ub-9Qjie7nvzTodRKtTxSwOO3I if this helps at all this is the printer i have
                                              • twistedechos
                                                also i went thought the stuff you sent and it didnt do anything i think i need to reuplaod the files on it but i dont think i did the maserments right on the reprap config i think that might be the problem how do i find them all i can find on google is the bed size
                                                • twistedechos
                                                  i feel so dumb i think i found the problem i did not put the files under sys it is under another folder ill let you know what i find out
                                                  • twistedechos
                                                    ok that fixed it oi lol but now the problem is i dont think i have the right measurements or the home set properly i went thought the reprap config again and i dont know the specs for the printer nor understand what to do with them
                                                    • twistedechos
                                                      found another problem haha sorry to be spamming but i had it as a corexy (what i thought it was) its a cartesian
