    duet 2 wifi ona ctc dual help plz
    7.5k
    • twistedechosundefined
      twistedechos
      https://3dprinting.com/pricewatch/3d-printer/ctc-bizer/?fbclid=IwAR1yXJLIZn4f_zbPCmQrPTTxfIqpmlKQ0ub-9Qjie7nvzTodRKtTxSwOO3I if this helps at all this is the printer i have
        twistedechos
        also i went thought the stuff you sent and it didnt do anything i think i need to reuplaod the files on it but i dont think i did the maserments right on the reprap config i think that might be the problem how do i find them all i can find on google is the bed size
          twistedechos
          i feel so dumb i think i found the problem i did not put the files under sys it is under another folder ill let you know what i find out
            twistedechos
            ok that fixed it oi lol but now the problem is i dont think i have the right measurements or the home set properly i went thought the reprap config again and i dont know the specs for the printer nor understand what to do with them
              twistedechos
              found another problem haha sorry to be spamming but i had it as a corexy (what i thought it was) its a cartesian
                twistedechos
                next problem i have no idea what im doing lol i got it to do stuff but its doing crazy stuff its like id dont know where to stop and anytime i home the axis it acts like it just adds the steps to where it already is i dont want to burn anything up would anyone be able to walk me though the https://configurator.reprapfirmware.org/Start
                  Ok, it sounds like you made some progress. Before you can get things working, you're going to have to figure out some details about the printer. The link you included above shows the build volume, so we have that part. We know it's cartesian. It seems to be dual extruder. it has a heated bed.
                  What we still need to know:
                  What kind of thermistor does the hotend heaters and bed heater have? If you have any documentation, or support forum for the printer that might help. Some googling might turn it up. That would help getting the temperatures right without having to do too much guess work.
                  We need to know what kind of end stops you have and where they are located. Even if you can take a picture of them inside the printer and how they are wired.
                  Does it have a Z probe?
                  Steps per mm for each axis. You might be able to find this googling, or looking at the setup for the stock firmware. Worse comes to worse it can be calculated if you know the model of the motor (usually a sticker on them), the tooth spacing of the belts, and the number of teeth on the pulleys. If that's too hard to get, you can start with a safe value and test how much it actually moves when you tell it to move 10mm and figure it out from there.
                  I think you'll also benefit from doing a lot of reading up on the firmware and how things work: https://duet3d.dozuki.com/
                  Here's an article on adapting an existing printer for the Duet. https://duet3d.dozuki.com/Wiki/Going_from_Marlin_on_Arduino_to_RepRapFirmware_on_Duet
                    twistedechos
                    thats the bad part i can not find any info on this printer and it dont have a z probe unless that is the z endstop non of the endstops seem to be working they light up when pressed but the stepper will try to keep moving ill get some pix for you guys in a sec
                      twistedechos
                      0_1553036067051_IMG_0113.jpg z end stop
                        twistedechos
                        0_1553036143380_IMG_0114.jpg y end stop
                          twistedechos
                          0_1553036255567_IMG_0115.jpg x end stop
                            twistedechos
                            belt is s2m and 17 tooth pullys z rod is the 8mm rod and a k type thermistor it is a 24v system if that helps with anything the bed thermistor is built into the bed
                              twistedechos
                              i did find this though https://www.thingiverse.com/thing:2475257/ im not sure what he means in the files though
                                @twistedechos said in duet 2 wifi ona ctc dual help plz:
                                s2m
                                S2M belts look like they have a 2mm pitch, just like GT2.
                                So 17 tooth pulley, 2mm pitch, 16x microstepping, and either 200 steps per rotation or 400 steps per rotation motors.
                                xy_steps_per_mm = (motor_steps_per_rev ∗ driver_microstep) / (belt_pitch ∗ pulley_number_of_teeth)
                                Gives you 188.2 steps per mm in X and Y if it's a 0.9 degree motor. Or 94.1 for a 1.8 degree motor.
                                No probe. That's fine.
                                The endstops look like makerbot style endstops, but there looks to be 4 wires going to them. It's really hard to see from the pictures. Maybe you could remove one of the endstops and take a good picture of the switch side with the wires. Also the wires at the other end that goes to the Duet. You'll need to identify which wire is which and how to hook it up to the Duet.
                                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
                                https://duet3d.dozuki.com/Wiki/Test_homing_behaviour
                                  Phaedrux Moderator @twistedechos
                                  So looking at that config.g file in his bundle
                                  ; Configuration file for Duet WiFi (firmware version 1.17)
                                  ; generated by RepRapFirmware Configuration Tool on Sat Jul 01 2017 14:45:41 GMT+0800 (Malay Peninsula Standard Time)
                                  M111 S0 ; Debugging off
                                  G21 ; Work in millimetres
                                  M208 X-12 Y-10 Z0 S1 ; Set axis minima (bed offset 12 and 10 from zero) <UPDATE> change to fit your bed dimensions - extruder should be over the rear right corner of the bed
                                  M208 X273 Y137 Z150 S0 ; Set axis maxima (reduced by offset above) <UPDATE> change to fit your bed dimensions
                                  ; Endstops- Switches
                                  ; M574 X1 Y1 Z1 S0 ; <ENDSTOP Z> Define active low and unused microswitches - uncomment to configure for legacy Z-Endstop switch
                                  ; Endstops- Z Probe <ENDSTOP Z> comment out section below if no Z probe is used
                                  M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
                                  M558 P1 X0 Y0 Z1 H5 F350 T150000 ; Set Z probe type to unmodulated (DC42 IR Probe), the axes for which it is used and the probe + travel speeds
                                  G31 P500 X-20 Y6 Z 2.662 ; Set Z probe trigger value, offset and trigger height - Increase Z value to move bed closer to nozzle (2.662 for black PEI)
                                  M557 X25:250 Y15:125 S20 ; Define mesh grid
                                  M569 P0 S0 ; Drive 0 goes backwards
                                  M569 P4 S1 ; Drive 4 goes forwards
                                  M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                                  M92 X88.573186 Y88.573186 Z400 E96.27520187033366:96.27520187033366 ; Set steps per mm
                                  M566 X900 Y900 Z600 E1200:1200 ; Set maximum instantaneous speed changes (mm/min)
                                  M203 X1080000 Y1080000 Z1200 E96000:96000 ; Set maximum speeds (mm/min)
                                  M201 X1000 Y1000 Z150 E2000:2000 ; Set accelerations (mm/s^2)
                                  M906 X800 Y800 Z400 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M143 S260 ; Set maximum heater temperature to 260C
                                  M305 P0 T100000 B3974 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                  M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                  M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
                                  ; Heater PID Values <UPDATE> Replace with your values from Autotune result
                                  M307 H0 A103.7 C787.7 D1.0 S1.00 B0 ; Set PID values for Heatedbed - derived from autotune
                                  M307 H1 A313.9 C153.8 D4.0 S1.00 B0 ; Set PID values for Extruder 1 - derived from autotune
                                  M307 H2 A352.7 C171.2 D3.5 S1.00 B0 ; Set PID values for Extruder 2 - derived from autotune
                                  M563 P0 D0 H1 ; Define tool 0
                                  M563 P1 D1 H2 ; Define tool 1
                                  G10 P1 X35 Y-0.8 Z0 ; Set tool 1 axis offsets <UPDATE> tune to suit your hot end - use a dual extrusion calibration model to find best values
                                  G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                  M207 S1.2 F1200 ; set 1.2mm retract distance for G10 command
                                  M550 PDuet_Replicator ; Set machine name <UPDATE> update with your desired Machine name
                                  M551 P12345678 ; Set password <UPDATE> update with your desired Password
                                  M552 S1 ; Enable network
                                  ; Access point is configured manually via M587 by the user
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S0 ; Disable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  ; Filament Cooling Fan <UPDATE> comment out section if no filament cooling fan is installed
                                  M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P0 S0 ; Switch cooling fan off
                                  ; Extruder Cooling Fan
                                  M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  It looks like he might be using 18 tooth pulleys. How sure are you that yours are 17 tooth?
                                  You may be able to copy and paste that config.g into your own file. It still won't help if the endstops aren't wired correctly.
                                    twistedechos
                                    i did modify the wiring with the end stops im sure i got it hooked up right but i can send a pic cus the duet is 3 wiers
                                      twistedechos
                                        twistedechos
                                        it is 17 i counted again was hoping maybe my eyes messed up or something
                                          @phaedrux said in duet 2 wifi ona ctc dual help plz:
                                          So if you have 17 teeth, I would change his X and Y from 88.5 to 94.1. You can test if this is correct by moving an axis and measuring how much it actually moves.
                                          If homing isn;t working correctly yuet, you can test movement by sending G92 X0 Y0 Z0 in the console to force the Duet to think it's homed. You can then carefully move the axis.
                                          Have you tested his config yet?
                                          The procedure for testing endstops should tell you if they are working.
                                          https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
                                            twistedechos
                                            end stops are working but the stepper will sit and bounce off of it? and when i did the G92 X0 Y0 Z0 it let me move it but then it stopped like it hit its max but it was in the center? and the 94.1 seems to be working well
