    slicer scaling behaviour... wild...
    3D Printing General Chat
    559
    • c310
      c310 last edited by
      Hi! I need help with simplify3d scaling… I am trying to print figure as below… In the model external size (marked with red) is 29.214mm and internal circle is 6.4 mm.
      Once printed in 100% scale external is 28.9 and internal is 5.0 ☹ once I adjust scale to 101,08 external prints with tiny difference, but internal is still very small. To print internal in right size I need to use 128% scale ☹ but it drives external size far away…
      Which settings should I consider to be changed?
      Many thanks!
      • OBELIKS
        OBELIKS last edited by OBELIKS
        Under Other tab on the Process settings you should have Horizontal size compensation. Change that to 0,7mm
        You should be close for the internal diameter.
        https://forum.simplify3d.com/viewtopic.php?t=2042
        But if you made the model, try increasing the dimensions.
        P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
        Original Prusa i3 MK3S
        • fma
          fma last edited by
          That's a huge différence; you may have some over-extrusion?
          Frédéric
          • OBELIKS
            At first I also thought of over-extrusion, but then also the outside dimension would be bigger, but it's also smaller.
            Something is not completely OK here.
            • fma
              fma last edited by
              My bad, I mis-read the outer dimensions!
              Frédéric
              • c310
                c310 last edited by
                @obeliks
                thanks! that is a very strange parameter for me. with test i have figured out that -0.25 mm worked with my 101,08 scale.. however that ratio brought down external size 🙂 in my particular case i can live with that, but it is very and very strange...
                • OBELIKS
                  Check X and Y steps/mm just to be sure.
                  • c310
                    c310 last edited by
                    slicer i guess is a crap... with settings above radial holes are tight as it should be, central one in loose.... in CAD they are all the same..
                    • fma
                      fma last edited by
                      I'm pretty sure you have a hardware/firmware configuration issue... There is absolutely no reason S3D changes holes dimensions depending where they are on the plate.
                      Frédéric
                      • c310
                        c310 last edited by
                        CAD settings are below. as well as motor settings. printer is delta
                        M569 P0 S1				; Drive 0 goes forwards
                        M569 P1 S1				; Drive 1 goes forwards
                        M569 P2 S1				; Drive 2 goes forwards
                        M569 P3 S0				; Drive 3 goes forwards (extruder)
                        M350 X16 Y16 E16 I1    			; Set 16x microstepping with interpolation
                        M574 X2 Y2 Z2 S1			; set endstop configuration (all endstops at high end, active high)
                        M666 X0 Y0 Z0				; put your endstop adjustments here, or let auto calibration find them
                        M665 R102 L288.17 B75 H152		; set delta radius, diagonal rod length, printable radius and homed height
                        ; H152 for standart
                        ; H142 for volcano
                        M92 X80 Y80 Z80				; Set axis steps/mm http://prusaprinters.org/calculator/#stepspermmbelt
                        M906 X1250 Y1250 Z1250 E700		; Set motor currents (mA) 85% of rated
                        M906 I30				; Set Idle factor to 30%
                        M201 X1000 Y1000 Z1000 E120		; Accelerations (mm/s^2)
                        M203 X20000 Y20000 Z20000 E600		; Maximum speeds (mm/min)
                        M204 P500 T2000				; Maximum Print and Travel acceleration
                        • fma
                          fma last edited by
                          As @OBELIKS said, re-check M92 values. And as your printer is a delta, re-check the calibration.
                          Frédéric
