    UNSOLVED bltouch and g28 head crash
    bltouch g28
    • ckigar
      ckigar last edited by
      When I issue a g28 z the bltouch does not deploy and the nozzle hits the bed.
      My Z endstop exists and is attached to the board; however it doesn't indicate as triggered on the machine properties tab. (x and y do)
      Firmware Version: 2.0(RTOS) (2018-06-05b3)
      WiFi Server Version: 1.21
      Web Interface Version: 1.21.1
      The printer is a Cartesian Makerfarm 'pegasus'. The bltouch is authentic.
      The commands:
      M280 P7 S160 I1; Alarm Release and Push-Pin UP
      M280 P7 S10 I1; Pin Down-- Send PWM channel 7 the s10 (angle) command
      M280 P7 S90 I1; pin up --Send PWM channel 7 the S90 (angle) command
      M280 P7 S120 I1; self test -- Send PWM channel 7 the S10 (angle) command
      work correctly.
      My config.g:
      0_1552929052793_config.g
        Can you post your homing files please?
        • ckigar
          4_1552943590416_homez.g 3_1552943590415_homey.g 2_1552943590415_homex.g 1_1552943590415_homedelta.g 0_1552943590414_homeall.g
          Here you go!
          I have the bltouch at ~8.3 mm from the glass to the shell. It is a bltouch smart.
            I suggest you update your firmware to 2.02.
            https://github.com/dc42/RepRapFirmware/releases/tag/2.02
            And remove M98 Pdeployprobe.g and M98 Pretractprobe.g from your homeall.g
            In config.g change G31 P500 to G31 P25
            And follow the directions here to test and calibrate the probe
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
