    Pause / Resume from DWC buttons - nasty head crash - but WHY?
    • SputnikOC3d
      SputnikOC3d last edited by SputnikOC3d
      I suspect the fact that I may have executed a few DWC commands from the windows - may have caused the board to lose track of its location ? I didnt think it would but perhaps it does. Trying to search for answers ...
      Done this a few times in the past but it no workieeee this time.
      Hit Pause ... Print head moves - sits idle with heat still on...
      Hit Macro - for releasing the Extruder Motor [ M84 E0 ]
      remove filament - cold pull style - manually ...
      insert new filament feed - press in till a bit of oozing [ petg 245*C ]
      tweez off ooze
      Hit Extrude for 50mm on the DWC panels buttons for Machine Control Window
      Hit Resume .... [ i remember it used to work ] .... but alas, in this case - hard crash into part.
      Looks like it was trying to go to gcode's beginning and print a Purge Strip.
      Clueless in Cali
      ; pause.g
      ; called when a print from SD card is paused
      ; generated by RepRapFirmware Configuration Tool on Wed Jan 31 2018 09:50:41 GMT-0800 (Pacific Standard Time)
      M83 ; relative extruder moves
      G1 E-4 F3600 ; retract 4mm of filament
      G91 ; relative positioning
      G1 Z5 F360 ; lift Z by 5mm
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      ; resume.g
      ; called before a print from SD card is resumed
      G1 R1 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 ; go back to the last print move
      G1 E4 F3600 ; extrude 10mm of filament to undo the retraction from Pause.g
      • resam
        resam last edited by
        Which firmware version are you using?
        I remember that one of the alpha or beta versions had a similar bug...
        • SputnikOC3d
          2.02RC5
          wifi 1.21
          web interface 1.22.5
            dc42 administrators @SputnikOC3d last edited by dc42
            @sputnikoc3d said in Pause / Resume from DWC buttons - nasty head crash - but WHY?:
            2.02RC5
            You should not use beta or RC firmware versions once the corresponding stable release is available (2.02 in this case). As @resam said, there was a known bug in this area in some 2.02RC versions.
            SputnikOC3d 1 Reply Last reply Reply Quote 0
            • SputnikOC3d
              SputnikOC3d @dc42 last edited by
              @dc42 said in Pause / Resume from DWC buttons - nasty head crash - but WHY?:
              2.02RC5
              Thanks David ...
              Lesson learned then. I wondered if I had changed something somewhere that may have caused it ... I had not had the printer up and working for over a month - and needed to get a friends parts printed ... asap. Didnt think to see if there was a new version before rockin and rollin. Lesson #2 learned 🙂
              Im up on all the latest stable full releases now.
              thanks to all for the assist.
