    Solved Extruder temperature drops after print start
    • Saentis
      Saentis last edited by
      I'm new to the Duet 2 Wifi and I'm coming across a problem that I haven't come across in my searches.
      I like to print at 215ºC and that's the temperature I've set in Cura. When I start a print, it gets up to that temperature and is able to get the first few layers of the brim when it stops extruding. I check the temperature and it's at ~160ºC. It looks like the active and standby temps change to 1ºC?
      These are my temp settings in Cura:
      Here's a video of it happening: https://app.box.com/s/0cst60mf3wstonf1fhc12uu0khpcqmfh
        Can you post the gcode file this happens with?
        • Saentis
          Yes, here's the gcode I tried printing in the video.
          0_1553521281512_TT_xyzCalibration_cube2.gcode
          • OBELIKS
            OBELIKS last edited by
            Try to print with disabled fan.
            P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
            Original Prusa i3 MK3S
            • OBELIKS
              Actually forget about that. I didn't check the provided sample.
              T0
              M190 S65
              M104 S215
              M109 S215
              M82 ;absolute extrusion mode
              ; start_gcode
              M117 Start Clean        ; Indicate nozzle clean in progress on LCD
              all good up to here
              M104 S[extruder0_temperature]
              M109 S[extruder0_temperature]
              M109 R[extruder0_temperature]
              This is probably your problem. Check the start gcode that you have in Cura and delete or comment out these lines
              • Saentis
                That seems to have fixed it. Thanks!
