    FTP transfer problem
    Firmware installation
    • paboman
      paboman last edited by paboman
      I am unable to transfer files using FTP connection from PC to the Duet while listing or deleting files is working fine.
      using last version of filezilla.
      I have created an entry in Site Manager for the Duet, and set it to "Max concurrent connections: 1".
      M550 PATLAS Technic 4030             ; Set machine name
      M552 S1                                              ; Enable network Module
      M586 P0 S1                                         ; Enable HTTP
      M586 P1 S1                                         ; Disable FTP
      M586 P2 S0                                         ; Disable Telnet
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6J9FL-3S46J-KDAWD
      Used output buffers: 1 of 20 (14 max)
      Static ram: 25524
      Dynamic ram: 98304 of which 0 recycled
      Exception stack ram used: 344
      Never used ram: 6900
      Tasks: NETWORK(ready,544) HEAT(blocked,832) MAIN(running,3860) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:18:08 ago, cause: software
      Last software reset at 2019-03-21 10:41, reason: User, spinning module GCodes, available RAM 6916 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 34.8, current 36.2, max 36.3
      Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 441/736
      Driver 1: standstill, SG min/max 416/738
      Driver 2: standstill, SG min/max 379/722
      Date/time: 2019-03-21 10:59:21
      Cache data hit count 2730962867
      Slowest loop: 21.12ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 5, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 237, MaxWait: 481439ms, Underruns: 0, 0
      Scheduled moves: 5, completed moves: 5
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 21.42ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(1) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      • paboman
        updated to the latest 2.03beta2 but still not working.
        • paboman
          Update, Using CoreFTP the transfers works as expected, so this is a Filezilla missconfiguration I think. But i havent changed any of the options
          • zapta
            zapta last edited by
            I am having similar problems with Cyberduck on Mac. Set it to use a single connection ('use browser connection') but can't download/upload, just list directories and files.
            I am 80% sure it used to work before I updated the firmware.
            paboman 1 Reply Last reply Reply Quote 0
            • paboman
              paboman @zapta last edited by
              @zapta try another ftp client, for me filezilla is not working while CoreFTP works just fine
              • thwe
                thwe last edited by
                FileZilla works for me with the following settings:
                • Tab General: Encryption - Only use plain FTP (insecure)
                • Tab General: Logon Type - Anonymous
                • Tab Advanced: Server Type - Default
                • Tab Tranfer Setting: Tranfer Mode - Passive
                Thomas
                • William
                  William last edited by
                  And if your on a mac.
                  • Tab Charset - Force UTF-8
