    Duet Ethernet Errors
    • jbolt
      jbolt last edited by
      I have a Duet Ethernet that I believe is about 1-1/2 years old on a CORE XY printer. It has run flawlessly up until a week ago when the board quit printing mid print during the night. Lights were on, fan off and a communication error on the web interface. I restarted the board and it worked fine for a few days and then quit mid print again. I was in the room when it happened this time and the blue, red, green lights on the borad were blinking on/off with what sounded like a relay trying to latch. Again restarting the board the issue cleared. On the next print, within 30 minutes, a "Warning: High Temperature on Driver 2" appeared and the Z axis stepper and the left side XY stepper stopped moving while the extruder and right side XY kept moving.
      I don't know if this is of any help but here is the M122 log while in the fault. Restarting the board again clears the fault but I don't trust that it will function for long.
      Used output buffers: 3 of 32 (9 max)
      RepRapFirmware for Duet Ethernet version 1.19 running on Duet Ethernet 1.0
      Board ID: 08DGM-95BNL-MGPSN-6JKDG-3SN6T-TKYVZ
      Static ram used: 17684
      Dynamic ram used: 95892
      Recycled dynamic ram: 1112
      Stack ram used: 1136 current, 8344 maximum
      Never used ram: 8040
      Last reset 02:41:15 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 11976 bytes (slot 0)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 37.4, current 38.4, max 44.6
      Supply voltage: min 9.0, current 23.5, max 23.9, under voltage events: 2, over voltage events: 0
      Driver 0: standstill
      Driver 1: stalled standstill
      Driver 2: standstill
      Driver 3: stalled standstill
      Driver 4: standstill
      Date/time: 2019-03-20 23:03:18
      Slowest main loop (seconds): 0.230408; fastest: 0.000000
      MaxReps: 3, StepErrors: 0, FreeDm: 240, MinFreeDm 150, MaxWait: 123496ms, Underruns: 0, 0
      Scheduled moves: 2, completed moves: 2
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.8
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      State: 5
      HTTP sessions: 1 of 8
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      • deckingman
        deckingman @jbolt last edited by deckingman
        @jbolt Your supply voltage shows a minimum of 9.0 while max and current voltages are over 23. That would indicate a PSU issue or perhaps a short somewhere.
        Edit....and two under voltage events reported.
          As @deckingman says.
          @jbolt said in Duet Ethernet Errors:
          That will be your PSU cutting in and out. The only question is whether this is due to a PSU fault, or because you have a short somewhere related to driver 2.
          • jbolt
            Okay thanks, I will change the PSU and see if that resolves the issue. If not, what would cause a short to suddenly happen?
