    External Trigger for syncing other devices.
    • MMNots
      MMNots last edited by
      Hi all,
      I'm trying to use Duet3d ethernet to build a 3D scanner. In order to do that I must be able to scan (receive data) after each move. Is there any way that I can send a trigger signal from duet board to my scope? I just need to know that one step is executed and the system is ready to receive data.
      • SupraGuy
        SupraGuy last edited by
        If you have control of the Gcode, I might be tempted to use a heater. Set up the Gcode to do a move command, then turn (for example) the E1 heater) on and back off again
        Your other control reads 0V on the heater - takes its reading, then sends Gcode to move, turn the heater back on. Rinse and repeat.
        Lead screw driven printer, powered by Duet Wifi
        MPCNC powered by Duet Wifi
          One of our OEMs is already using a scanner with Duet. I don't know the details, except that it uses a Raspberry Pi to do the scan, communicating with the Duet over USB. RRF supports GCodes M750 thru M756 for this purpose.
          • fma
            fma last edited by
            Maybe using I²C, with a circuit, like PCF8574/74A?
            Frédéric
