    Power loss recovery
    • hussainsail2002undefined
      hussainsail2002
      Re: Power Loss Recovery and Power Supply Question
      I am trying to building a 3D printer with the power loss recovery feature.
      Is it possible to wire the capacitor to the leads that act as Vin and ground for the board ?
      It has been said in an older post that the capacitor should be 10000uF rated at 35V.
      Is there any wiring diagram that can be followed.
      Thanks,
      Hussain.
        dc42 administrators @hussainsail2002
        Yes you can do that. However, if you are using a typical 24V power supply then it probably has a spare set of output terminals wired in parallel with the ones you are using to feed the Duet, and it's simpler to connect the capacitor to those spare terminals.
        hussainsail2002undefined 1 Reply Last reply Reply Quote 1
          hussainsail2002 @dc42
          so if I understood correctly,
          when the power fails, the capacitor connected would discharge and power the other terminals ??
            @hussainsail2002 said in Power loss recovery:
            Yes, that's correct for a standard 24V PSU with 2 or 3 sets of output terminals connected in parallel. It may not be true for a 12V ATX PSU because those sometimes have multiple independent 12V outputs.
              Thank you !
