    Duet wifi Controller interface won't accept password
    • Magnusjen
      Magnusjen last edited by
      I got my replacement duet wifi board because the other was defective (yay)! I went through the whole setup again and put in the config file. But wanted to reconfigure it, when I did this it asked for the password. I gave it the password and then another million times and it refuses.. So I tried connecting with USB and via YAT change the password using M551 Pnnn but this didnt work either. I have tried looking around the forum, but you put "wifi" and "password" in the same search and it is cluttered with other searches..
      So, basic question is, how do I gain access to the interface when it won't accept the simple password I gave it?
      Best regards
      Magnus
      Magnusjen 1 Reply Last reply Reply Quote 0
      • Magnusjen
        Magnusjen @Magnusjen last edited by
        @magnusjen
        Waaait a minute... I am in bed now and was just thinking cant i just take the SD card and configure IT without password?
          dc42 administrators @Magnusjen last edited by dc42
          @magnusjen said in Duet wifi Controller interface won't accept password:
          @magnusjen
          Yes you can.
          It gets tricky if your password contains accented characters, but it should still work if you save config.g to the SD card in UTF8 format.
          Preferably, surround the password with double quote characters, for example:
          M551 P"reprap"
          • Magnusjen
            Magnusjen @dc42 last edited by
            @dc42 It worked 🙂 finally I am setting up the axis etc. hopefully tommorow I will start my first duet print
