    use PT100 sensor for extruder 0 sensor
    Third-party add-ons
    • yaman
      yaman last edited by
      hi all
      I want to know if I can use PT100 with PT100 Daughter Board for extruder 0 tool 0 sensor
      what the command I should to use
      I try to use command M305 but I think this command for bed heater .
      also I try to connect PT100 direct to tool 0 sensor but it give me wrong reading for temperature
      so can any one tell my witch command define tool sensor
        See https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors#Section_Firmware_configuration.
        • A Former User
          If you're having issues with making the configuration with the web based reprap configurator, try V1 instead. I ran into all sorts of trouble when trying to set up PT100 with the new.
          I think I saw a thread that may have fixed the issue, but I haven't tried it myself.
          But yes, I use PT100 on daughterboard for both bed and extruder.
          ;H0 = bed
          ;H1 = E0 hotend
          M307 H0 B0 P1 F10 V0                                 ; 10Hz PID, ignore voltage compensation (mains powered)
          M305 P0 X201                                         ; Configure thermocouple for heater 0
          M143 H0 S120                                         ; Set temperature limit for heater 0 to 120C
          M301 H1 S0.70                                        ; Set heater 1 PWM limit to 70%
          M305 P1 X200                                         ; Configure thermocouple for heater 1
          M143 H1 S280                                         ; Set temperature limit for heater 1 to 280C
          • yaman
            yaman last edited by yaman
            yep it's work
            before that I try command M305 more then 100 time and it's won't work
            after I restart the controller I use command M305 P1 X202 and the magic happen from first time 🤔 🤔
            thanks ☺ 👌
            • A Former User
              Do you have two PT100 boards, or is M305 P1 X202 meant to be something else?
              • yaman
                yes I have two PT100 boards
