    Required offset in x and y not equal?
    • DocTruckerundefined
      DocTrucker
      Got an issue where I have a gap between the perimeters and infill when the perimiter is parrallel to the x axis of my ormerod but fine on the gap to the perimeter when parrallel to the y axis.
      Any idea what could be up? Axis of nozzle not quite parallel to the bed normal/z axis?
        DocTrucker
        Should add that the infill pattern is 45 degree with rotation on alternate layers.
        Filament diameter (volumetric extrusion) tuned so walls are correct size by a micrometer when extrusion multiplier is 1. For the prints the extrusion multiplier is 0.95, which is the lowest without a number of gaps appearing in the print. Pressure advance is off. Material is PLA at 200C which just began to get a shiney finish on a temp tower. E-steps set up without hotend, then non linear extrusion set up (and tested) to correct extrusion at upto 10mm3/sec when extruding into free space.
        • jmjcokeundefined
          jmjcoke
          What Slicer are you using?
          Joshua Coke
          Trick Laser Metal Max with Smart Effector
          Duet Wifi
          Zesty Nimble
          Mosaic Pallette+
          At work
          Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
            DocTrucker
            Development version of Slic3r.
            • jmjcokeundefined
              jmjcoke
              I have noticed this same issue and worked to find out why. I ended up trying other slicers and problem was not happening with either of the other slicers.
              I like Kisslicer but I get the gap in one axis and not the other, but my parts are dimensionally very accurate. ( I shouldn't say "axis" because it is at one end of a 45 degree infill, no matter how I rotate the part.)
              Joshua Coke
              Duet Wifi
              Zesty Nimble
              Mosaic Pallette+
              At work
