    Resurrect goes missing
    • hunterwsundefined
      hunterws
      I have a RMXv4 delta printer, and have seen the resurrect prologue on the SD card before.
      Was going to test it today, and there are no resurrect files anywhere on the card.
      I can reinstall it easy enough, but I know what's going to happen, when I need it, it will have disappeared.
      The printer company said printers go out with the file on the SD card.
      I visited this issue when I had a power outage, and no files on the printers SD card on my other printer (RMX3.2)
      What would make it disappear?
        The resurrect-prologue file is one that you have to create yourself (except perhaps if you buy the Duet as part of a printer kit and the supplier includes it), because its contents are highly dependent on your printer. The resurrect.g file is created when a print is paused for any reason, and deleted when a print finishes normally. See https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure.
        • hunterwsundefined
          hunterws
          ok, thank you for the post, I'll just try it during a print, and see if the file generates
