    Cura 4 barely extruding
    • mlaustin6undefined
      mlaustin6
      I can extrude no problem with Simplify3d and slic3r. I tried to use Cura today and barely get any extrusion. There are no issues with extrusion multipliers. My start gcode is as follows:
      G90 ;absolute positioning
      G28 ;Home
      G92 E0
      I have printed on prior version of Cura. Am I missing some kind of setting? It's on reprap gcode flavor.
      • Vetiundefined
        Veti
        check that you did not accidentally set filament diameter to something other than your filament size.
          mlaustin6
          I had it set to 1.75mm, and it somehow reverted back to 2.85. Thanks.
            Phaedrux Moderator @mlaustin6
            @mlaustin6 said in Cura 4 barely extruding:
            If you use Cura long enough, this is bound to happen to you. Very common problem.
