    Ezabl and deployprobe.g and retractprobe.g
    573
    • mringersoll
      mringersoll last edited by
      Hello I tried a search for it but got nothing could someone give me an example of these 2 files please so i know what is needed keep getting error messages about M208 Ect Ect.
      Thank You
      Mike
        AFAIK the EZABL is just an inductive or capacitive sensor with an interface, and doesn;t need to be deployed or retracted. In which case, you don't need deploy por retract files.
        • mringersoll
          Thank You for quick reply question though if they are not in the Sys folder SD card i get error that they can not be found so could you give me the commands for the config.g file to get this error to stop i must have a wrong command or something i also get alot of errors about skipped readings from probe is there a way to get it read the probe quicker or something
          Mike
            No error message is generated if deployprobe.g and retractprobe.g are not present when they are invoked implicitly. Are you invoking them explicitly using M98 command in bed.g? If so, delete those commands.
            What is the exact error message?
              Can you post your config.g and homing files as well?
              What probe type do you have defined in M558?
              • Modtcass
                Modtcass last edited by
                Search my posts and it shows my config for the EZABL.
                • mringersoll
                  4:50:59 AM
                  Warning: Skipping grid point (188.0, 163.0) because Z probe cannot reach it
                  Warning: Skipping grid point (188.0, 188.0) because Z probe cannot reach it
                  4:50:33 AM
                  Warning: Skipping grid point (188.0, 113.0) because Z probe cannot reach it
                  Warning: Skipping grid point (188.0, 138.0) because Z probe cannot reach it
                  4:50:08 AM
                  Warning: Skipping grid point (188.0, 63.0) because Z probe cannot reach it
                  Warning: Skipping grid point (188.0, 88.0) because Z probe cannot reach it
                  4:49:42 AM
                  Warning: Skipping grid point (188.0, 13.0) because Z probe cannot reach it
                  Warning: Skipping grid point (188.0, 38.0) because Z probe cannot reach it
                  config.g below
                  ; generated by RepRapFirmware Configuration Tool v2 on Fri Apr 05 2019 09:57:11 GMT-0500 (Central Daylight Time)
                  M575 P1 B57600 S1
                  M550 P"My Hacked Ender 3" ; Set machine name
                  M552 S1 ; Enable network
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M569 P0 S0 ; Drive 0 goes backwards
                  M350 X16 Y16 Z16 E16 I1 ; Configure micro stepping with interpolation
                  M92 X81.13 Y81.14 Z400.00 E93.13 ; Set steps per mm
                  M566 X950.00 Y950.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X4000.00 Y4000.00 Z280.00 E160.00 ; Set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z25.00 E250.00 ; Set accelerations (mm/s^2)
                  M906 X400.00 Y400.00 Z400.00 E400.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X-5.5 Y-5.5 Z0 S1 ; Set axis minima
                  M258.5 X245 Y245 Z255 S0 ; Set axis maxima
                  M574 X1 Y1 S1 ; Set active low and disabled end stops
                  M574 Z1 S2 ; Set end stops controlled by probe
                  G1 E-2
                  M558 I1 P5 X0 Y0 H2.5 F220 T6000 R0 ; Set Z probe type to switch and the dive height + speeds
                  G31 P900 X-46 Y-11 Z-.047 ; Set Z probe trigger value, offset and trigger height
                  M557 X13:210 Y13:210 S25 ; Define mesh grid
                  M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                  M563 P0 S"Main" D0 H1 ; Define tool 0
                  ; Automatic power saving
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                  Stephen6309 1 Reply Last reply Reply Quote 0
                  • Stephen6309
                    Stephen6309 @mringersoll last edited by
                    @mringersoll said in Ezabl and deployprobe.g and retractprobe.g:
                    4:50:59 AM
                    4:50:33 AM
                    4:50:08 AM
                    4:49:42 AM
                    You need to adjust the M557 to eliminate the warnings. You either need to reduce or increase the max X & Y.
                    • mringersoll
                      maybe so but my printer bed is 235 x 235 and i have watched it probe and it is still over the bed when the errors occur so a bit confused.
                      Phaedrux TheRulesLawyer 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @mringersoll last edited by Phaedrux
                        @mringersoll are you sure you have the signs right in your g31? Is the 0,0 origin point in the front left corner? If not you may have an axis direction flipped.
                        The X-46 in your g31 doesn't seem to add up with the x values from your m208 and m557.
                        • TheRulesLawyer
                          TheRulesLawyer @mringersoll last edited by
                          @mringersoll
                          The issue is the offset of your probe. I have a ezabl and I have to tell it to probe a smaller area because the nozzle would have to travel outside the bed. For example my probe is +48x I have to tell it I want to probe +50 to + 250 on my cr10 otherwise I get that error. (Technically I could probe out to +300, but I'm trying to make it even. I'm guessing your offset isn't allowing you to reach +188.
                          • mringersoll
                            ok I am really getting frustrated here my bed is 235 x 235 offset of probe by Marlin settings X - 46 Y - 11 so can you please give me some settings to try Please so offsets are the same in RepRap just very confused and getting to the point of giving up on this Duet Ender 3 project.
                              @stephen6309 said in Ezabl and deployprobe.g and retractprobe.g:
                              4:50:33 AM
                              4:50:08 AM
                              4:49:42 AM
                              Ok, so try this. Move to the points listed in the error message. Can your probe actually reach those points?
                              • TheRulesLawyer
                                TheRulesLawyer last edited by
                                This may be an error. I'm not sure what m258.5 does.
                                Try replacing with
                                M208 X235 Y235 Z255 S0 ; Set axis maxima
                                I'm not sure if you meant to add the extra travel or not. When you zero x/y is the nozzle over the bed?
