Motors not moving
My printer is a sunhokey prusa i3 and had a ramps 1.4 board. I now have a Duet Maestro. I have setup firmware config via the online configurator. I believe the board is wired correctly. All lights appear to be on. I have checked the motors are configured. I can't remember exactly what I did but they all got 800w.
I do get an error though when doing the "initial test". It says 11.6v is lower than expected or something like that. I'm at work right now so can't remember the exact error message. I can manually move the z motor but the X and y do not respond and it says the axis haven't been homed. If I press home all it does nothing.
I tried the motor test under initial test and the z axis went all the way down and slammed into the bed and wouldn't stop. I think that's because the z stop switch got pushed down because it was moving so fast. Anyway the issue is that the X and Y motors aren't responding. -
Motors won't move until their axis is homed unless you override it with https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
I'd suggest you get to the bottom of why you have Z but not X and Y homed though. For which you should share your config.g and homeall.g files and someone will probably be able to help you.
Maybe this guide will help
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
@bearer I figured out the end stop switches were wrong thanks to @Phaedrux . The motors still aren't moving properly. They kind of move, but very slowly and but as far as I request them too. I copied the steps per mm from my old marlin config. Below is the config file from my duet maestro.
; Configuration file for Duet Maestro (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v2 on Sun Jun 30 2019 17:49:29 GMT+1000 (Australian Eastern Standard Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"Benji" ; Set machine name
M552 P192.168.1.20 S1 ; Enable network and set IP address
M553 P255.255.255.0 ; Set netmask
M554 P192.168.1.1 ; Set gateway
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S1 ; Physical drive 0 goes forwards
M569 P1 S1 ; Physical drive 1 goes forwards
M569 P2 S1 ; Physical drive 2 goes forwards
M569 P3 S1 ; Physical drive 3 goes forwards
M350 X256 Y256 Z256 I0 ; Configure microstepping without interpolation
M350 E16 I1 ; Configure microstepping with interpolation
M92 X80.5 Y80.5 Z405.6 E644.81 ; Set steps per mm
M566 X80?5 Y80.5 Z405.6 E644.81; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X200 Y200 Z180 S0 ; Set axis maxima; Endstops
M574 X0 Y0 Z0 S0 ; Set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
M557 X15:150 Y15:150 S20 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M307 H0 A594.9 C285.1 D2.7 V11.2 B0 ; parameters set by me from PID autotune.
M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
M143 H0 S90 ; Set temperature limit for heater 0 to 90C
M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
M143 H1 S190 ; Set temperature limit for heater 1 to 190C; Fans
M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings
M918
Homeall.g
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 S1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 S1 X-205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 S1 Z-185 F1800 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
@benji said in Motors not moving:
could be the ? in there is tripping your config up?
(edit: incidentally if you run
M98 Pconfig.g
in the g-code console it'll run through the config and maybe give you some indications of errors) -
@bearer yes that is a silly error which I only just added. I corrected it but still it didn't fix anything. I tried. I just noticed that if I press home all the X starts moving towards the switch very slowly and stops before it gets there and then moves towards the y switch very slowly and stops. Each time I get the error "G0/G1 insufficient axes homed"
you'll get "G0/G1 insufficient axes homed" as long as you don't hit the endstop with a G0/G1 command that has a S1 or S3 flag set, or use G92 to set the axis to 0, or allow the override with M564.
do but if you have copied your steps/mm from Marlin, and set the duet to use 256 microsteps, then that'll explain slow speed and short moves. either multiply your steps/mm by 16 or reduce the microstepping to 16 with interpolation to 256?
you should use the x16 with interpolation for all axis unless there is a very specific reason not to.
running at x256 will put an unnecessary load on the cpu that could in some cases cause problems while printing. -
@bearer ok thanks. That might help. I'll try that tomorrow.
@veti is that microstepping though? It's one of the main reasons I went with this board. I just don't know much about it though
Yes, hes saying that you should keep the steps/mm as is and reduce the microstepping to 16, and let the driver handle the interpolation to 256 microsteps.
Ok, thanks all. Hopefully this works. Then I'll move on to the next issues.
@bearer ok. So multiplying all steps by 16 worked. Except the extruder went ridiculously fast so I put that one back to what I had it.
Now I have two other issues. Or three really but only two are important.
1.) I can't get the hotend to start under active mode. Only standby mode.
2.) The hotend fan never starts
3.) I have a 12864 LCD that never comes on.I believe it's all wired correctly.
So you're still using 256 microstepping? That's going to lead to issues down the line.
I'm not sure what you mean about the hotend in active/standby mode. Can you describe what you're trying to do?
For the fan, how do you have the hotend fan connected? The hotend fan should be connected to fan port 1.
I just noticed a problem with your config for fan0.
; Fans M106 P0 S0 I0 F500 H T45
The last bit should be H-1 and no T45 so that it is controlled by the slicer for part cooling.
How do you have the 12864 display wired up? What type/brand of display is it?
Have you seen https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system ? In particular, the bit about using M918 P1 in config.g to enable the display.
My bad, as you had the config for 256 microsteps for xyz and 16 for the extruder I asumed it was deliberately and for a purpose; and as such would understand the steps only needed changing for xyz.
But if you don't have a reason for using 256 microsteps I would suggest you go the other way and change all the microsteps to 16 and let the driver handle the interpolation to 256 like you had it for the extruder (and divide the xyz steps by 16 again).
@bearer do you mean that if i set to 16 i will still get 256 microstepping somehow?
@phaedrux i did have the P1 originally which did enable it.
Then i'd follow up with M918 and it would say its enabled and working but the lcd doesnt light up. -
@dc42 yes i tried that. it says its enable but nothing comes up on the screen.
I tried plugging into the paneldue one and the screen at least lights up but nothing on the screen.
I have copied the /menu folder contents to the right place
