    Motors not moving
    1.5k
      A Former User @Benji
      @benji said in Motors not moving:
      M566 X80?5 Y80.5 Z405.6 E644.81
      could be the ? in there is tripping your config up?
      (edit: incidentally if you run M98 Pconfig.g in the g-code console it'll run through the config and maybe give you some indications of errors)
      Benjiundefined 1 Reply Last reply Reply Quote 0
      • Benjiundefined
        Benji @A Former User
        @bearer yes that is a silly error which I only just added. I corrected it but still it didn't fix anything. I tried. I just noticed that if I press home all the X starts moving towards the switch very slowly and stops before it gets there and then moves towards the y switch very slowly and stops. Each time I get the error "G0/G1 insufficient axes homed"
          A Former User
          you'll get "G0/G1 insufficient axes homed" as long as you don't hit the endstop with a G0/G1 command that has a S1 or S3 flag set, or use G92 to set the axis to 0, or allow the override with M564.
          do but if you have copied your steps/mm from Marlin, and set the duet to use 256 microsteps, then that'll explain slow speed and short moves. either multiply your steps/mm by 16 or reduce the microstepping to 16 with interpolation to 256?
          • Vetiundefined
            Veti
            you should use the x16 with interpolation for all axis unless there is a very specific reason not to.
            running at x256 will put an unnecessary load on the cpu that could in some cases cause problems while printing.
            Benjiundefined 1 Reply Last reply Reply Quote 1
            • Benjiundefined
              @bearer ok thanks. That might help. I'll try that tomorrow.
              • Benjiundefined
                Benji @Veti
                @veti is that microstepping though? It's one of the main reasons I went with this board. I just don't know much about it though
                  A Former User
                  Yes, hes saying that you should keep the steps/mm as is and reduce the microstepping to 16, and let the driver handle the interpolation to 256 microsteps.
                  • Benjiundefined
                    Benji
                    Ok, thanks all. Hopefully this works. Then I'll move on to the next issues.
                    • Benjiundefined
                      @bearer ok. So multiplying all steps by 16 worked. Except the extruder went ridiculously fast so I put that one back to what I had it.
                      Now I have two other issues. Or three really but only two are important.
                      1.) I can't get the hotend to start under active mode. Only standby mode.
                      2.) The hotend fan never starts
                      3.) I have a 12864 LCD that never comes on.
                      I believe it's all wired correctly.
                      Phaedruxundefined dc42undefined A Former User? 3 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @Benji
                        So you're still using 256 microstepping? That's going to lead to issues down the line.
                        I'm not sure what you mean about the hotend in active/standby mode. Can you describe what you're trying to do?
                        For the fan, how do you have the hotend fan connected? The hotend fan should be connected to fan port 1.
                        I just noticed a problem with your config for fan0.
                        M106 P0 S0 I0 F500 H T45
                        The last bit should be H-1 and no T45 so that it is controlled by the slicer for part cooling.
                        How do you have the 12864 display wired up? What type/brand of display is it?
                          dc42 administrators @Benji
                          Have you seen https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system ? In particular, the bit about using M918 P1 in config.g to enable the display.
                            ; Custom settings
                            M918
                            Looks like you're just missing the P1
                              My bad, as you had the config for 256 microsteps for xyz and 16 for the extruder I asumed it was deliberately and for a purpose; and as such would understand the steps only needed changing for xyz.
                              But if you don't have a reason for using 256 microsteps I would suggest you go the other way and change all the microsteps to 16 and let the driver handle the interpolation to 256 like you had it for the extruder (and divide the xyz steps by 16 again).
                              • Benjiundefined
                                @bearer do you mean that if i set to 16 i will still get 256 microstepping somehow?
                                • Benjiundefined
                                  Benji @Phaedrux
                                  @phaedrux i did have the P1 originally which did enable it.
                                  Then i'd follow up with M918 and it would say its enabled and working but the lcd doesnt light up.
                                  • Benjiundefined
                                    Benji @dc42
                                    @dc42 yes i tried that. it says its enable but nothing comes up on the screen.
                                    I tried plugging into the paneldue one and the screen at least lights up but nothing on the screen.
                                    I have copied the /menu folder contents to the right place
                                    • Benjiundefined
                                      Benji @Phaedrux
                                      @phaedrux said in Motors not moving:
                                      I mean that when i choose a temperature in active shown in the image and go to active mode it does nothing but it works in active mode.
                                        Yes, somehow. If you ask the driver to move 1/16th of a step (i.e. 1 step pulse) the driver will divide that step into another 16 steps, resulting in 256 steps being made to move 1/80th of a millimeter. You need a very rigid machine to make use of any finer resolution than that.
                                        • Benjiundefined
                                          @bearer so do i choose x16 or x16 (on)
                                            Not all 12864 displays are the same, some have different pinout and different controllers. Pictures clearly showing the wiring may help identify problems
