    G32 Report
    • Ozzzzzzyundefined
      Ozzzzzzy
      Can i run a second G32 after the first one does its adjustments to get a report without adjustments. It always says it is at 00.00 but when i run g32 again there is always a little error.
      • Vetiundefined
        Veti
        have you checked the repeatability of your probe?
        see
        https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output
          dc42 administrators @Ozzzzzzy
          @ozzzzzzy said in G32 Report:
          Copy your bed.g file to another macro file; then change the S parameter on the final G30 command to S-1 to get a report only when you run that macro.
          Ozzzzzzyundefined 1 Reply Last reply Reply Quote 0
          • Ozzzzzzyundefined
            Ozzzzzzy @dc42
            @dc42 Cool that is what I wanted to do. Thank You
            • Johncoffeeundefined
              Johncoffee
              @Ozzzzzzy
              Can you explain again the purpose of your task? I don't really understand what you are trying to achieve.
              Thanks a lot.
              Finally upgraded my trusty Rostock Max V2 from Rambo v1.4 to Duet Wifi & 7" screen & BLtouch sensor. Installed end of June 2019
              Prusa Mk2 MMU1.0
              • Ozzzzzzyundefined
                Ozzzzzzy
                @johncoffee If I run a G32 more than once it gets better. My first run it usually is around 0.0355 off and then says its corrected to 00.00. If I run it again it says it was 0.0075 and corrected to 00.00 and so on. But sometimes it gets worse. Its probably the error in my lead screw distances. I just want to check after the adjustment when its around .007 or better I am good. I am using 2 lead screws and a chimera.
                Johncoffeeundefined 1 Reply Last reply Reply Quote 0
                  Johncoffee @Ozzzzzzy
                  @ozzzzzzy Got it. ✌ Thanks for your explanation 🙂
                  Prusa Mk2 MMU1.0
