Bltouch Probing Question
The M98 command in your bed.g file may be causing this.
I just edited both those files and rebooted but it is the same. Removed the M98 command in bed.g and removed the X0 Y0 Z1 from the M558 command
@dc42 said in Bltouch Probing Question:
Any other ideas? Im using a genuine bltouch now and I've deleted the M98 command as well as the X0 Y0 Z1 from the M558 command but it still does the same thing
What is in your deploy and retract files?
deployprobe.g is just one line M280 P7 S10 I1
retractprobe.g is M280 P3 S90 I1 -
@57buick said in Bltouch Probing Question:
Im using version 2.0
That firmware version is fairly out of date at this point. There have been some BLTouch changes since then.
Try updating to version 2.03 by going to the settings tab and uploading this zip file: https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
Full release notes here: https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
@phaedrux said in Bltouch Probing Question:
Awesome! I just updated and everything seems to be working properly, thanks. One question I dont see on the pages anywere that specify what is the latest version of wifi server and web interface etc. Are these all the latest versions?
Firmware Version: 2.03 (2019-06-13b2)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6 -
Yes those are latest stable versions. There is also a beta of DWC 2.0 for those who want to try it.
@57buick By uploading that single combined zip file all the relevant firmwares, etc get updated.
Awesome thank you guys! I am ordering two more Duet boards for my Folgertech FT5 printers so I will make sure and install that file to those too
Note that that single file upload process only works with boards that are already running firmware 2.0 to begin with. If it's an older firmware you'd need to update the individual files first to at least 2.0
good to know
