    Continuous vertical lines on shell
    44
    4.8k
      dc42 administrators @nophead
      @nophead said in Continuous vertical lines on shell:
      If the striations are vertically aligned doesn't that rule out the extruder? I mean wouldn't it be a remarkable coincidence to have a perimeter that was an exact multiple of the extruder microsteps or tooth pitch?
      Isn't it more likely axis speed modulations?
      That's a good point. But if it's axis speed modulations, why does it change with layer height?
      • Diamondbackundefined
        Diamondback @nophead
        @Diamondback ,
        Is the pitch of the lines related to the belt tooth pitch?
        Do you have any toothed belts running tooth side inwards over smooth pulleys?
        I'm not quite sure how I would relate the line pitch to the belt pitch, any tips?
        I do have a smooth idler facing the teeth on the Y-axis (which is also the axis that shows the issue more), I have the correct toothed idler around, attaching it just ended up being a pain so I left the stock (smooth) one in there.
        I wonder though why this wasn't an issue from the beginning when I got the printer, possibly softer teeth than my Gates belt now? Ie the teeth just being depressed enough that it didn't really matter?
        @dc42 said in Continuous vertical lines on shell:
        Hm maybe something to do with some extruder jerk or whatever value leading to different speeds at higher flowrates? Pressure advance?
          Phaedrux Moderator @Diamondback
          @diamondback said in Continuous vertical lines on shell:
          The belt pitch is likely 2mm. Is the distance between ridges also 2mm?
          Diamondbackundefined 1 Reply Last reply Reply Quote 0
            Diamondback @Phaedrux
            @phaedrux said in Continuous vertical lines on shell:
            The pitch seems to be something like 1.2mm (averaged over 7 peaks), hard to measure...
            nopheadundefined 1 Reply Last reply Reply Quote 0
            • petrzmaxundefined
              petrzmax
              I have measured mine and it was the same distance which You measured.
              • nopheadundefined
                nophead @Diamondback
                @diamondback How many teeth on your pulleys?
                If it isn't related to belt pitch then perhaps motor steps.
                  Both idler and pulley have 20 teeth on both axis.
                  • petrzmaxundefined
                    petrzmax
                    I have found the solution. You need to use teeth idlers instead of flat.
                      Diamondback @petrzmax
                      @petrzmax said in Continuous vertical lines on shell:
                      Glad this worked for you 🙂 I'm in the middle of switching my idler to a toothed one as well, need to fabricate a custom screw first though, the idler is 5mm ID and the attachment is an M4 screw....
                      petrzmaxundefined 1 Reply Last reply Reply Quote 0
                      • petrzmaxundefined
                        petrzmax @Diamondback
                        @diamondback I'm in fabricating phase aswell. The research I made told me that it should make ghosting less visible and get rid of this lines. Unfortunatelly i have not standard derlin idlers so I will need to print idlers. I hope they will be good quality. If they will not I will need to buy metal ones and redesigns some parts which I'm trying to avoid.
                        • nopheadundefined
                          nophead @petrzmax
                          @petrzmax This is how I first solved the problem: http://hydraraptor.blogspot.com/2011/06/half-belt-hack.html
                          For Mendel90 I just put a half twist in the return path of the belt because toothed idlers were not commonly available then.
                          • petrzmaxundefined
                            petrzmax @nophead
                            @nophead Thanks for the idea! I will try to give it a go, but I'm on CoreXY and ther might be a problem with twisting them. Never tried twisting them before 🙂
                            • nopheadundefined
                              nophead
                              @petrzmax Not sure it will work on core XY because the you can only put the twist in a stretch that doesn't contract to a short length, ideally constant length like above. I am working on an H-bot design and concluded I needed toothed idlers.
                                Diamondback
                                Ok, got my idler changed now to the correct toothed one, but that didn't do much I'm afraid...
                                So back to extrusion related issue I guess. Anything I can try to adjust software wise before taking the Titan apart?
                                Maybe someone can take a look at my config.g in the first post and see if there are any obvious issues
                                • nopheadundefined
                                  nophead
                                  If you print something with different outside dimensions do you ever get diagonal lines? I can't see how the extruder can create vertically aligned striations.
                                  How many shells are you using. With single wall I sometimes see striations from the infill pattern through the wall.
                                  • mrehorstdmdundefined
                                    mrehorstdmd
                                    I use F608 bearings for idlers in my corexy printer with the toothed side of the belts riding on them. I get no such vertical ridges. Maybe you need to use larger diameter pulleys. F608s are 22 mm in diameter.
                                      Diamondback
                                      I'm usually using 3 shells at .4mm, the lines are always perfectly vertical, sometimes there are diagonal lines on top of that, not sure where those comes from.
                                      • nopheadundefined
                                        @diamondback What happens on diagonal sides?
                                        If it was somehow a flow rate variability synchronised between layers I would expect it to look exactly the same.
                                        If it is due to variations in linear speed due to motors or belts I would expect the pitch to increase on a diagonal because each axis is moving slower for the same linear speed.
                                          Diamondback
                                          Just tested, straight vs diagonal do differ quite a lot. I'm currently test printing something without micro step interpolation.
                                          • petrzmaxundefined
                                            @diamondback Let us know about the results! 😉
