    Backlight control
    PanelDue
    • totalosundefined
      totalos
      Hi.
      How do I set the panel to turn off the backlight automatically, for example after printing ?
      Is it possible to send some g-code to the backlight settings to the panel? (panel 5" integrated).
        On the Setup page on the PanelDue there is an option for backlight dimming.
        What version of PanelDue firmware are you running?
        • totalosundefined
          totalos
          Thank you for your response.
          I have 1.23.2 firmware.
          I see DIM option but need set dim to a lower brightness level or preferably completely turn off lighting.
          Is it possible to control it?
          hestiahuangundefined 1 Reply Last reply Reply Quote 0
            I don't think it can currently be turned off completely.
            • hestiahuangundefined
              hestiahuang @totalos
              @totalos
              Buzzer::SetBacklight(0);
              • totalosundefined
                totalos
                Thank you. But I can not compile it.
