Corexy Z offset
I us this sample: Find Z-offset: https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
when you did the calibration. did you verify that the printhead was on the bed when you moved to z=0?
Yes when the printhead touched bed I put G92 Z0 and then G1 Z10 and G30 S-1 and I got z offset
And I used the code M564 S0 to disable axis limits and that it
no one can help me? I found a couple of posts on the forum with the same problem but none of the solutions listed there does not work for me.
Here is an sample https://forum.duet3d.com/topic/3055/having-trouble-setting-the-z-offset
and here is second https://reprap.org/forum/read.php?416,762755
and one more https://forums.matterhackers.com/topic/536/solved-z-offset-not-working
But the main problem is like mine. -
@chris11 is it possible that not exact BL Tutch alignment to the print nozzle can cause such height differences?
i am still waiting for you to verify that after homing (G28) and going to Z=0 (G0 Z0) that the printhead is not 3mm above the bed.
@veti said in Corexy Z offset:
G0 Z0
but today I set the BLTouch height more precisely. I did the offset measurement again and got a 0.950 result.
when I move the hotend to the table from the control panel the z axis shows me 0.00
but 0.5mm is still missing to zero -
if you cant get a good result with that. increase the offset and do a first layer test print. increase the z offset until it produces a good enough first layer.
any value I would not enter has no effect on the distance between the nozzle and the table, 0.5mm to zero is still missing
Your M558 contains X0 Y0 Z1.
Why did you put them there?
remove them and try again. -
how are you editing the config.g btw?
I removed it, I did again Z offset 0.951
still on the main panel Z shows 0.00 but the nozzle is 0.5mm above the table -
and if you set the offset to 1.4?
also check under settings, machine properties, that the z offset is actually set.
how can I check under settings, properties, I think I have not done before, what do you mean?
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
section Machine Properties
Look for trigger height
