Dudes about pressure in advance
I have put the setup line of pressure in advance in config.g... But pressure un advance depends of filament and nozzle....
Pressure in advance will work the same manner if I put these line in start gcode of slicer? These perment change easy if i change the kind of filament or nozzle
@peirof Yes you can do that.
Thanks..
I usually put a PA value in my config.g that is in the ballpark of what i need for most filaments, for when i print with a random filament that i haven´t tuned completely.
For the Filaments that i tuned the PA for, i put the PA values in my start gcode in my slicer settings, which override the config.g then. -
If Pressure in Advance (PA), is setup in config.g..... and in star gcode (Of slicer). What PA has priority?
One option can be...
A- Stablish in config.g one default parameter for PA, for the normal filament do you use..
B- When you use a diferent filament, setup in start gcode.... this is always possible if gcode PA has priority.... -
@peirof With any gcode, including pressure advance, the latest command will over ride anything that came before. Your config.g file gets read as soon as you apply power to the board so the command that is config.g will get read first. But when you come to print something, if you have gcodes at the start of your print file, then these will get read and override any previous values.
