    BL-Touch and the Duex 5
    68
    7.4k
    • JustDundefined
      JustD
      Hmm, The Check the Flat-Cable with a multimeter.. and it´s all OK.. if the Pin 1 is 5V and pin2 is GND at the DUEX...
      Power-connection.. .. yes.. the Z-Axis (drive 5-7) and Extruder at Drive 8 running well.. and I´m absolutly shure.. I connected the 24V from the Duet correct at the DUEX.
      or is there any Jumper to set, if I use the Duex with 24V instead of 12v?
      At my picture above, you can see teh connection of the spare BLTouch.. if this is OK.. then this is also rigth.
      Anything forgotten?
      I´m open for anything..
      Own Tronxy X5S modified to 360x360x430, 7 linear-rails (4 Z; 2 Y; 1 X-Axis), 3 independent Z-Axis with 3 Steppers; BL-Touch..
      Duet 2 Wifi 1.04 + DUEX5, 3input-nozzle with 3 extruders, 6mm Glas Plate and 600W silicon-headbed with own powersupply.
        This weekend I should be able to find some time to duplicate a BLtouch on Duex configuration.
        Until then I'm all out of ideas.
        • JustDundefined
          JustD
          Oh Thank you for your Help.. . I search many thing on Google.. with Duex & BLTouch.. not really new things
          I also think about .. maybe it is possible the complete Duex... or a voltage regulator is damaged.. who knows..
          But otherwise.. the complete.. no.. driver 5-8 are running perfectly..hmm. strange .. very strange.
          I´m all of edge.. what is the reason for this.
          • JustDundefined
            JustD
            Does anyone have had a similar problem with the PWM´s?
              It sounds to me that the BLTouch isn't getting +5V from the DueX. Have you checked that you have connected it correctly?
              • JustDundefined
                JustD
                15 times I checked it.. (see the pic a little above, with a spare BLTouch direct connected)
                Yes.. what I´m wondering... I can´t messure the 5V at the Duex5
                Is the Board partial damaged??? .. But this sounds strange for me... because all other functions are running.
                I think I start a Test with Fans.. or so.. to check if the Problem bigger or not.
                • JustDundefined
                  JustD
                  I found with search funktion this Thread... very interesting for me.
                  https://forum.duet3d.com/topic/6876/bltouch-on-fan-or-heater-pins-on-duet-wifi/5
                  So I tested it.. and now.. the BLTouch has power.. thats OK and LED is going on.
                  But only at the first power on, the BLTouch doing a selftest.. pin-down and pin-up.
                  After I change the configuration as described, no function.. no more pin-down and no selftest.
                  But if I start a command, the BLTouch is directly blinking all the time.
                  What about the:
                  M558 P9 H7 F500 T9000 X0 Y0 Z1:U1:V1:W1 ; Set Z probe type 9 to bltouch (P5 as Betrue3D) and the heater (7) height + speeds (+ B1)
                  Or should it change to
                  M558 P9 P22 F500 T9000 X0 Y0 Z1:U1:V1:W1 ??
                  I Do so.. and I´m able to start Macro´s and the BLTouch is going up and down. (M280 P22 I1 S10 / M280 P22 I1 S90)
                  But Alarm rest + Pinup didn´t work now (M280 P22 I1 S160)
                  Maybe you have here a solution for me?
                  Here may Config:
                  ; Mapping of Driver for X,Y, Z1-3, E1-3
                  M584 X0 Y1 Z5:6:7 U5 V6 W7 E3:4:8 ; three Z motors connected to driver outputs 5, 6 and 7 (U,V,W), driver 8 for E2
                  M667 S1 ; Select CoreXY mode
                  ; BLTouch - Heater 7
                  ;M307 H7 A-1 C-1 D-1 ; Disable heater 7 to free up PWM channel 5 on the Duex board.
                  M106 P2 I-1 ; Disable Fan2 Duet to free up PWM channel 22 on the Duex board.
                  ; Define the X and Y coordinates of the leadscrews.
                  ; Must come after M584 (Set drive mapping), M667 (Select CoreXY Mode) and M669 (Choosing Kinematics type)
                  ; Motor order: Front right (1), front left (2), rear center (3).
                  ; Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
                  M671 X0:320:162 Y0:0:320 S3
                  M569 P0 S0 ; Drive 0 goes backwards X
                  M569 P1 S0 ; Drive 1 goes backwards Y
                  M569 P3 S0 ; Drive 3 goes backwards E0 (E1)
                  M569 P4 S0 ; Drive 4 goes backwards E1 (E2)
                  M569 P5 S0 ; Drive 5 goes backwards Z1/U
                  M569 P6 S0 ; Drive 6 goes backwards Z2 V
                  M569 P7 S0 ; Drive 7 goes backwards Z3 W
                  M569 P8 S0 ; Drive 8 goes backwards E2
                  M350 X16 Y16 Z16:16:16 U16 V16 W16 E16:16:16 I1 ; Configure microstepping with interpolation
                  M92 X80 Y80 Z800:800:800 U800 V800 W800 E93:93:93 ; Set steps per mm
                  M566 X900 Y900 Z12:12:12 U12 V12 w12 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X12000 Y12000 Z800:800:800 U800 V800 w800 E1200:1200:1200 ; Set maximum speeds (mm/min)
                  M201 X500 Y500 Z300:300:300 U300 V300 W300 E250:250:250 ; Set accelerations (mm/s^2)
                  M906 X950 Y950 Z1800:1800:1800 U1800 V1800 W1800 E950:950:950 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X0 Y0 Z0 U0 V0 W0 S1 ; Set axis minima
                  M208 X324 Y324 Z355 U355 V355 W355 S0 ; Set axis maxima
                  M574 X1 Y2 S1 ; Set X=low end Y= high end active high endstops
                  M574 Z1 S2 ; Define Z1 to use Probe at low End. Home to Min. S2 = Z probe
                  ; M558 P9 H7 F500 T9000 X0 Y0 Z1:U1:V1:W1 ; Set Z probe type 9 to bltouch (P5 as Betrue3D) and the heater (7) height + speeds (+ B1)
                  M558 P5 P22 F500 T9000 X0 Y0 Z1:U1:V1:W1 ; Set Z probe type 5 at bltouch (P5 as Betrue3D) and the FAN2-PWM height + speeds (+ B1)
                  ; G31 P25 X+33 Y0 Z0.894 ; Set Z probe trigger value (1-25, not 500), offset and trigger height (3fach-PH noMixing)
                  G31 P25 X+26.4 Y15.8 Z0.894 ; Set Z probe trigger value (1-25, not 500), offset and trigger height (Diamond-org)
                  M557 X45:325 Y25:325 S30 ; Define mesh grid
                  M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 (Bed)
                  M143 H0 S125 ; Set temperature limit for heater 0 to 125C
                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 (Nozzle)
                  M143 H1 S285 ; Set temperature limit for heater 1 to 285C
                  ;M140 S35 ; set Bed-Temp to 35C at Starttime
                  M106 P0 S0.5 I0 F500 H1 T105 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P1 S1 I0 F500 H1 T105 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  ;M106 P2 S0.3 I0 F500 H1 T105 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on / (off=H-1)
                  But for a first Result.. the BLTouch working now... LED is on.. Z-Axis stop at BLT is triggering.. great..
                  Last point seem so... the Alarm + PinUp still didn´t work .
                  I don´t know why?
                  Z-Probe-Type 9 didn´t work at my printer.. only 5.
                  • JustDundefined
                    JustD
                    After first Test to print...this problem:
                    2. The third Extruder didn´t working. (drive 8 at DueX)
                    Here my relevant config:
                    M584 X0 Y1 Z5:6:7 E3:4:8 ; three Z motors connected to driver outputs 5, 6 and 7 (U,V,W), driver 8 for E2
                    M106 P2 I-1 ; Disable Fan2 Duet to free up PWM channel 22 on the Duet board.
                    M671 X0:326:162 Y326:326:0 S3
                    M350 X16 Y16 Z16:16:16 E16:16:16 I1 ; Configure microstepping with interpolation
                    M92 X80 Y80 Z800:800:800 E93:93:93 ; Set steps per mm
                    M566 X900 Y900 Z12:12:12 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X12000 Y12000 Z800:800:800 E1200:1200:1200 ; Set maximum speeds (mm/min)
                    M201 X500 Y500 Z300:300:300 E250:250:250 ; Set accelerations (mm/s^2)
                    M906 X950 Y950 Z1800:1800:1800 E950:950:950 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M208 X328 Y328 Z390 S0 ; Set axis maxima
                    M558 P5 P22 F500 T9000 X0 Y0 Z1 ; Set Z probe type 5 at bltouch (P5 as Betrue3D) and the FAN2-PWM height + speeds (+ B1)
                    G31 P25 X+26.4 Y15.8 Z1.289 ; Set Z probe trigger value (1-25, not 500), offset and trigger height (Diamond-org)
                    M563 P0 D0 H1 ; Define tool 0
                    M563 P1 D1 H1 ; Define tool 1
                    G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
                    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                    M563 P2 D2 H1 ; Define tool 2
                    G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
                    G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                    Startcode in Slicer (Simply3D)
                    G91 ; Relative Positioning
                    G1 Z-1 ; Move Z down 1mm
                    G90 ; Absolute Positioning
                    G28 XY ; Home XY
                    M561 ; Clear any bed transform
                    G1 X104.5 Y153 ; Move Probe to middle of bed
                    G32 ; Start 3-point probe sequence
                    M375 P"GlasPlate.csv" ; Load my custom heightmap. Otherwise use G29 S1
                    G1 Z10.0 F6000 ; Move Z to 10
                    G1 X5 Y310 ; Move Head to front right
                    G92 E0 ; Zero Extruder
                    ;G1 F200 E20 ; Prime the extruder
                    ;G92 E0 ; Zero Extruder
                    ; Drucker von dem Probepunkt auf die Vordere Kante fahren für Testlinie
                    G1 X20 Y320
                    ;hier startet die Initiale Testlinie
                    G92 E0 ; filamentwegreset
                    G92 E1 ; filamentwegreset
                    G1 F300 E-0.5
                    G1 F800 E13.5
                    G1 X20 Y320 Z0.32 F1000 ; startpunkt
                    G1 X150 Y320 E30 ; linie 1
                    G1 X150 Y318 ; versatz
                    G1 X20 Y318 E60 ; linie 2
                    G1 X0 Y320 Z10 ; Zwischen Fahrweg
                    G92 20 ; filamentwegreset
                    G1 Z10.0 F9000 ; Move Z to 10
                    My Bed.g
                    G29 S2; Clear bed height map
                    ; Probe 3-point
                    M98 Pdeployprobe.g ; deploy mechanical Z probe
                    M401 ; Deploy probe - deployprobe.g
                    G30 P0 X3 Y320 Z-9999 ; Front Right
                    G30 P1 X320 Y320 Z-9999 ; Front Left
                    G30 P2 X160 Y5 Z-9999 S3 ; Center Rear
                    M402 ; Retract Probe - retractprobe.g
                    My deployprobe.g
                    M280 P22 I1 S10
                    My retractprobe.g
                    M280 P22 I1 S90
                    ; Homez.g
                    G90 ; Make sure we are in absolute mode
                    G1 X150 Y150 F8000 ; move probe to bed center. Adjust to make the probe be in the center of the bed. Note that X and Y must be homed first.
                    G30 ; Do a single probe to home our Z axis
                    G1 Z10 F8000 S2 ; Rapidly move the Z axis to Z=10
                    G1 X0 Y325 ; return to home position. Adjust as needed.
                    Does anyone know what the Problem is?
                    • JustDundefined
                      JustD
                      OOh.. damn.. I see.. a tools without filament didn´t work...
                      So after I set a Filament at the 3rd extruder.. it works...
                      So.. now the first really Testprint
                      Now I strugeling with wraping.. . I think thats only a question of time.. to solve this too.
                      • JustDundefined
                        JustD
                        So.. my Printer is now working really good.
                        Wrapping is also solved.
                        Only the right parameters for Sienoc ABS.. thats may problem.. with wrapping.. needs more experience.
                        PLA works very good.
                        If anyone needs my Config´s and so on.. give me a notice.. I will poste it with pic´s of wiring.
                        A big Thanks at the supporters here.. helps a lot.
                        Great Forum/Blog.
                          dc42 administrators @JustD
                          @justd, thanks for updating us! I'm glad to hear is is working well.
                          • JustDundefined
                            JustD
                            It´s a workaround... the Duex5 PWM Channels 1-5 still not working..
                            I don´t know why...??
                            But for now.. it´s working.. and I´m all the time printing.. 😉 this day´s.
                              What have you done that is a workaround?
                              • JustDundefined
                                JustD
                                Teh workaround is.. I´m using the FAN-PWM at the Duet2 instead of the Duex5 PWM 5 for the BLTouch probing..
                                like this Thread
                                https://forum.duet3d.com/topic/10978/bltouch-isn-t-working-after-change-to-duex-5
                                So the Duex5 is still not working 100% .. but for the Moment (and I need the printer) .. it is printing.. thats ok OK for the next weeks..
                                After this.. I will check it again.. to find the really problem with the Heater-PWM Channel 1-5..
                                I miss the 5V Power for the BLTouch
                                  The differences between using a Duet fan connector vs. using a DueX5 connector are:
                                  • Using the fan connector, you will need the I1 parameter (that's letter-i followed by digit-one) in the M280 commands that control the BLTouch. Using one of the PWM connectors on the DueX, you must not use the i1 parameter.
                                  • The way you free up the connector for use as the PWM control pin is different: M106 P# I-1 for the fan connector, and M307 H# A-1 C-1 D-1 for the DueX output.
                                  • JustDundefined
                                    JustD
                                    @dc42 said in BL-Touch and the Duex 5:
                                    M106 P# I-1
                                    I used as following
                                    ; BLTouch
                                    G31 P25 X+24.5 Y+5 Z1.345 ; Set Z probe trigger value (1-25, not 500), offset and trigger height (3fach-PH noMixing)
                                    M106 P0 S0.5 I0 F500 H0:-1 T175 C"Objekt-Fan-175" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                    M106 P1 S1.0 I0 F500 H0:-1 T90 C"Tool-Fan-90" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                    ;M106 P2 S0.3 I0 F500 H0:1 T105 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on / (off=H-1)
                                    • Hugo Hiaslundefined
                                      Hugo Hiasl
                                      In case someone comes to this issue also (even when the thread is already some months old).
                                      I had exactly the same behaviour that was driving me crazy. It took a while to recognize that the PWM 5V+ Aux needs a jumper to be set.
                                      It should default to use internal 5V. But on my Duex5 board there was no jumper set. For that reason the PWM5 port did not get 5V+.
                                      I marked it green on the following image.
                                      I hope this can help some users to get rid of that source of problems.
                                      Credits: Original image from here: https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
                                      • JustDundefined
                                        JustD
                                        Hi Hugo, thanks for this Input, sounds good.
                                        I will check it in the next 2-3 Weeks (some other work).
                                        But great if this would work also for me.
                                        • JustDundefined
                                          JustD
                                          I´f checkt it.. and .. Tata... YES.. it´s working now.. Great
                                          Now my BL-Touch is running at PWM5, Heater 7
                                          my Object-FAN is working and the control in Web-Control, a little different as I expected.. but it´s working.
                                          Thanks for the final inspiration with 5V for BLT.
                                          • pmvianaundefined
                                            pmviana
                                            Can you just share your config.zip file, your setup is very close to mine but I'm struggling with similar issues:
                                            • wobbling on the z axis with 3 independent steppers/drivers
                                            • a bltouch that tests but doesn't deploy when homing Z axis
                                            Best regards,
                                            Pedro Viana
