Is there a output that indicates active printing?
Hi There,
Is there an output from duetwifi that tells me a print has started / in progress so I can run lights on the machine to indicate this, and also run a hour meter.We run printers in an industrial environment, so I would like people to know that a printer could be starting so they don't mess with it.
@nz_andy said in Is there a output that indicates active printing?:
Hi There,
Don't know if this would do what you want but it might.
All of the slicers I have used have a section to enter custom gcode to execute on the start of a print and the end of a print, although there is often a few lines of code the will be executed before and after the code you get to enter.
I simply enter M98 Pprint_begin.g for the starting code and M98 Pprint_end.g for the ending code.
print_begin.g and print_end.g are gcode files that reside on the Duet. I can enter whatever code I need into these files.
One thing that happens in print_begin.g is the turning on of the LED light strips that illuminate the object being printed. They are turned off in print_end.g
You can use start.g and stop.g to turn on/off specific pins on the board (configuring the pin as a GPIO using M950 and turning it on/off using M42) and wire a led or even an SSR to that pin to control something external. You can use any of the unused pins like endstops or unused pins in the expansion header.
You can build one of those. All design files are open sourced.
https://forum.duet3d.com/topic/10720/duet3d-monitor-adding-a-big-status-light-to-your-printer/1
Thanks for the help, much appreciated, some good options there.
