    Z offset control
    1.2k
    • ABDELRHMAN SAMIR ABOGABALundefined
      in marlin and ramps i can change the z offest through the lcd
      how can i cahnge the z offset in duet through lcd
      if not how can i control and change it
      • StephenRCundefined
        StephenRC
        The z offset is controlled by G31. See: https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed
        It can also be set in macros. Which is handy, since different filament types and temperatures need a different z offset and I just call the needed macro in the slicer's start gcode. I do have it in config.g using the setting for the most common filament used on the printer.
        • ScotYundefined
          ScotY
          Is there a way to adjust z-height on the fly while printing? Would be so nice to be able to do this. Currently, I have to abort the print, edit config.g, then start a new print…time consuming and frustrating.
            This has been covered in earlier threads. You can do it by setting up macro files that do small Z movements followed by G92 commands. I plan to implement babystepping in firmware 1.18.
            • jrledererundefined
              jrlederer
              Interested in seeing the implementation via firmware 1.18. Thanks for all the hard work ; you're amazing!
              "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
              • ScotYundefined
                ScotY
                Could you steer me to these threads? I don't know what to search for.
                  T3P3Tony administrators
                  ScotY search for babystepping:
                  https://www.duet3d.com/forum/thread.php?id=666#p6414
                  https://www.duet3d.com/forum/thread.php?id=210#p1958
                  and the 1.18 provisional change list:
                  https://www.duet3d.com/forum/thread.php?id=598#p5718
