    BLTouch working
    266
    79.5k
    • Jdn-zaundefined
      Jdn-za
      W3DRK, So I have wired up my bltouch int he way that have described but cant seem to get my duet to deploy or retract using macros or gcode.
      I have the following defined in my config.g
      ; BLTouch
      M307 H3 A-1 C-1 D-1
      M558 P4 X0 Y0 Z1 H3 F200 T5000
      G31 P200 X-4 Y40 Z2
      I am running the latest stable dc42 fork of the Duet 0.8.5 firmware
      Firmware Version:	1.17a (2017-01-02)
      Web Interface Version:	1.14-RC1
      Any ideas what to look at?
      • tomwang256undefined
        tomwang256
        Are you on duet 0.8.5 or duet wifi? I have BLTouch wired up with my wifi working well.
        it's mostly the same instruction that W3DRK but the expansion header is not the same on the wifi so you would have to use pin 8 for Heater 3 pwm output instead.
        see documentation here : https://duet3d.com/wiki/Duet_WiFi_wiring_diagrams
        • Jdn-zaundefined
          Jdn-za
          @tomwang256:
          I am using the Duet 0.8.5
          • Jdn-zaundefined
            Jdn-za
            Ha! seems my signal wire was busted 😛
            My deploy marco works though the retract doesn't
            deploy
            M280 P3 S10 I1
            retract
            M280 P3 S90 I1
            If I home Z it deploys, lowers and reads the height then deploys and flashes
            • Jdn-zaundefined
              Jdn-za
              Seems I just had the wrong value in my retract macro… awkward 😛
              • InSanityundefined
                InSanity
                First post to the forum.
                I have the BLtouch working with my Duet Wifi, well somewhat. It homes fine and has consistent heights. The problem I'm having is with the new Grid compensation. I fire off the deployprobe.g in the bed.g followed by G29 and the machine goes to the first probe point , probes and then moves to the next. The 2nd point gets the following error :
                G32
                Error: Z probe already triggered before probing move started
                This of course is because the probe doesn't get deployed again once triggered by the first probe point.
                Hopefully someone can tell me where my error in logic is. It seams to me like the deploy is just not being called between points, possible flag to allow that ?
                Thanks,
                Jeff
                Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                • Sniffleundefined
                  Sniffle
                  M558 P4 X0 Y0 Z1 H4 F400 T500
                  http://reprap.org/wiki/G-code#M558:_Set_Z_probe_type
                  On M558 you need to set an H parameter so that the bed(or X axis) will move away from the probe(giving the probe room to allow the pin to fall back into the deployed position) so that it will not error(blinking probe will cause the endstop to be considered triggered always) you may also need to increase your F parameter to increase the speed of movement on the Z axis so that also doesnt cause the probe to error.
                  The probe should not be retracted between probing. It should trigger and drop back down each time. If you deploy the probe manually using M280 with plenty of clearance from the bed and use your finger to push the pin up it should pull away from your finger flash red and then drop back down when operating correctly. the retract probe command should only be done after finishing the probing.
                  • InSanityundefined
                    InSanity
                    I must be doing something wrong when I deploy the probe. No matter what the pin always gets sucked back up instantly. The probe isn't going into error mode at all, it just never stays deployed after being triggered.
                    This is what I'm doing with the deployprobe.g file. (M401)
                    M280 P3 S10 I1 ;Deploy probe
                    G4 P75 ;Wait 75ms
                    M280 P3 S60 I1 ;Test mode
                    G4 P125 ;Wait 75ms
                    This triggers as expected however it always sucks the probe up the instant it's triggered and doesn't try to drop it. If I don't include the "test mode" it just slams into the bed and then eventually triggers and goes into alarm. The bed doesn't even try to retreat until well into a crash. Even on a home without the test mode it just crashes into the bed.
                    I would have expected the trigger to occur the moment the pin reaches a certain level like it does while in the Test Mode.
                    BTW I'm running a Flashforge Creator Pro with the Duet WiFi , New Steppers, new carriage and the E3D Legends Pack. All new wiring with a 24 pin Molex MicroFit 3.0 on the back so I can swap out carriages. Prints like a champ with an inductive sensor, the IR sensor I just didn't have much consistency with.
                    Jeff
                    • InSanityundefined
                      InSanity
                      Playing around over here. I changed the deploy to
                      M280 P3 S160 I1 ;Clear any alarm
                      G4 P450 ;Wait 75ms
                      G4 P75 ;Wait 75ms
                      I went from H 3 to H 5 and F 120 to 320, now it just crashes faster and never tried to retreat. The probe still goes into alarm mode. It's as if the trigger is delayed, I don't see this problem if I put the probe in Test Mode. I'm using the Z-Probe into for the trigger, I can't imagine that would matter. I can toss a scope on the pin to see what it's doing I guess.
                      Jeff
                      • InSanityundefined
                        InSanity
                        Ok I'm starting to think it is a problem with the Z-Probe not responding fast enough for the 50ms pulse. I'm going to try the Z Endstop. The Z-Probe input does have a 10k resistor and a small cap, I can't imagine that would take too long to reach a good logic level. We shall see.
                        Jeff
                        • InSanityundefined
                          InSanity
                          I meant to say E0 in my last random thought. In any event I'm seeing the exact same behavior. The bed crashes, the trigger is not seen unless I put the probe in test mode. I'm running 1.17a firmware.
                          Jeff
                          • Sniffleundefined
                            Sniffle
                            according to the bltouch people, to work with 3.3v logic electronics you only need a 240ohm resistor in line with the 2-wire endstop. that could be where your not gettign a response. I will say that the web browser doesnt always refresh the probe trigger value fast enough for the trigger to show and I also have my z-probe trigger value set obscenely low to something like 25 since the pulse is so short.
                            G31 X-30 Y35 Z1.1 P25
                            as to the deploy this is all my macro is(on H3) M280 P3 S10 I1
                            I clear alarms separately as i feel that is just a safety check.
                            • InSanityundefined
                              InSanity
                              The resistor is in place. It trigger's just fine if I put the probe in test mode. I've tried the Z-Probe input and now E0 input. The web interface does show they trigger with the probe in test mode. The problem is without that test mode during a home (or probe) the bed just crashes and doesn't stop until the probe goes into alarm which forces the trigger. It's still acting as if the Duet Wifi just can't see that short pulse, which I find hard to believe. The logic levels are clearly ok as it's working while the probe is in test mode. I'm only clearing the errors in the deploy for now as I'm tired of doing so manually during this debug phase.
                              Any ideas ?
                              Jeff
                              • InSanityundefined
                                InSanity
                                I just love how helpful people are, much thanks.
                                The problem is my config override still had G31 P500, I changed that to P25 as suggested. It just never crossed my mind to look at this. Sniffle, your a life savor!
                                Now to switch back to the Z-Probe input.
                                Thanks,
                                Jeff
                                • Sniffleundefined
                                  Sniffle
                                  hmm… if you manually deploy the pin, and the press it up with your finger as if ti were probing does it display the trigger in the web interface? the default action in test mode and alarm is to send a constant signal instead of a pulse. When manually testing mine it doesnt always line up with a web interface value refresh but i could occasionally get it to show.
                                  • InSanityundefined
                                    InSanity
                                    Everything is working perfectly now.
                                    I can confirm the BLTouch works perfect with the Z-Probe input as well as E0 or E1. In either case be sure to use the 240 (or 220) ohm resistor from signal to gnd.
                                    I can also confirm you must have a low value for G31 P parameter. I'm now using P1 and it works perfect, P25 is a safe value it would appear.
                                    On a side note and certainly not for everyone I'm using a 47k resistor a 100k resistor and a green LED on the Z-Probe input to act as a zener diode limiting the voltage to around 2.7v even if I go as high as 24v on the Z-Probe. I have two harnesses that I can quickly swap out for all this testing. The 100k resistor acts to pull the signal back down. The 47k is a current limit and the LED is between gnd and signal. I've tested this on a 300 Mhz scope and even trying to cause spikes with 24v I never had anything go above 2.7v. Plus it lights up when triggered 🙂
                                    Jeff
                                      Perhaps one of you who has a BLTouch working would like to add a section on how you did it to the wiki page on connecting a Z probe?
                                      • InSanityundefined
                                        InSanity
                                        @dc42:
                                        I was thinking the same thing. Be happy to work on that, perhaps combining knowledge first and then compiling it together.
                                        Jeff
                                        • Sniffleundefined
                                          Sniffle
                                          I'll be happy to help with anything but for the most part i pulled everything from W3's work.
                                          • Sniffleundefined
                                            Sniffle
                                            This is pretty much what I did. Bur I also made macro's for the deploy, retract, reset and self test functions of the probe.
                                            @W3DRK:
                                            • BLTouch 5V leads are connected to expansion header pins 1-2, and the servo lead is connected to pin 21 (PWM for heater 3)
                                            • BLTouch endstop leads are paralleled with a 240ohm resistor as documented by Antclabs to make it safe for 3.3v logic and connected to E0 endstop header
                                            • [c]M307 H3 A-1 C-1 D-1[/c] is added to config.g to reserve pin 21 for M42 or servo use
                                            • M558 is set to probe type 4 and G31 is set for a very low trigger value since the BLTouch only triggers the endstop for 5ms(Sniffle used 25)
                                            • Deployprobe.g macro contains the line [c]M280 P3 S10 I1[/c] to deploy the BLTouch probe
                                            • Retractprobe.g macro contains the line [c]M280 P3 S90 I1[/c] to retract the BLTouch probe
                                            • Deploy and Retract macros are added to bed.g and homing macros
                                            And I think that's about it…
                                            Also as far as commissioning the probe, and notes of interest from experience
                                            the probe should be deployed and manually triggered until a value is seen in the web interface(the web interface doesnt update fast enough to always show a triggered state so it may take a few/several triggers until you see the value in the web interface to know that it works)
                                            you should know or confirm your offsets for X and Y in G31 move the probe to the first probe position and deploy the probe, if it is off the bed and the bed is too high it WILL destroy the probe(ask me how i know…) when probing, and adjustments must be made.
                                            to finally verify that the probe is working properly using the machine itself use the following macro(replace xxx on X and Y to a safe value to be on the bed on your printer)
                                            G28 X Y ;home x&y
                                            G91 ;relative mode
                                            G1 Z10 ;move Z up 10 mm to ensure clearance
                                            G90 ;absolute mode
                                            G1 Xxxx Yxxx ;move to a safe probing point on the bed modify xxx to your liking
                                            M98 Pdeployprobe.g ;deploy the probe
                                            G30 S-1 ;probe Z until the probe triggers
                                            M98 Pretractprobe.g ;retract the probe after triggering and stop.
                                            Other Useful Macros
                                            Deploy Probe
                                            M280 P3 S10 I1
                                            Restract Probe
                                            M280 P3 S90 I1
                                            Self Test Probe
                                            M280 P3 S120 I1
                                            Reset Probe Error State
                                            M280 P3 S160 I1
                                            G29 - Mesh Leveling
                                            G28
                                            G91
                                            G1 Z4 F200
                                            G90
                                            M98 Pdeployprobe.g
                                            G29 S2
                                            G29
                                            M98 Pretractprobe.g
                                            G1 X10 Y10 F5000
