BLTouch working
266
79.3k
    StephenRC
    @deckingman:
    I currently use DC42s excellent probe which works fine but the slight issue I have is that I have 3 pieces of glass with different surface coatings that I swap between. So if I go from say, plain glass with 3DLAC to glass with blue tape, I have to edit my config.g to change the Z offset for that particular surface.
    Use a macro to set the z offset. I have one for pla and another for petg. The two different filaments need a different z0 setting to get it to stick properly.
      Treito
      Did you directly connect the Servo to Pin21? Does this PIN provide 5 volts or would I need some sort of diode?
        Jdn-za
        Just ordered myself a bltouch and will be adding it to my duet 0.8.5, thanks for documenting the install mate
          Sniffle
          W3DRK, just curious, does each successful probe actually reflect in the web interface for you? I have mine setup nd everything is working but to test before i have a bed crash i deployed the probe and manually actuated the pin maybe 1 in 10 seems to actually register in the interface though.
          just to make sure i slowed my manual testing speed way down but still had several swipes that werent displayed on the interface.
          on my meter my resistor came out to 241ohms so it "should" signal ok…
            Jdn-za
            W3DRK, So I have wired up my bltouch int he way that have described but cant seem to get my duet to deploy or retract using macros or gcode.
            I have the following defined in my config.g
            ; BLTouch
            M307 H3 A-1 C-1 D-1
            M558 P4 X0 Y0 Z1 H3 F200 T5000
            G31 P200 X-4 Y40 Z2
            I am running the latest stable dc42 fork of the Duet 0.8.5 firmware
            Firmware Version:	1.17a (2017-01-02)
            Web Interface Version:	1.14-RC1
            Any ideas what to look at?
              tomwang256
              Are you on duet 0.8.5 or duet wifi? I have BLTouch wired up with my wifi working well.
              it's mostly the same instruction that W3DRK but the expansion header is not the same on the wifi so you would have to use pin 8 for Heater 3 pwm output instead.
              see documentation here : https://duet3d.com/wiki/Duet_WiFi_wiring_diagrams
                Jdn-za
                @tomwang256:
                I am using the Duet 0.8.5
                  Jdn-za
                  Ha! seems my signal wire was busted 😛
                  My deploy marco works though the retract doesn't
                  deploy
                  M280 P3 S10 I1
                  retract
                  M280 P3 S90 I1
                  If I home Z it deploys, lowers and reads the height then deploys and flashes
                    Jdn-za
                    Seems I just had the wrong value in my retract macro… awkward 😛
                      InSanity
                      First post to the forum.
                      I have the BLtouch working with my Duet Wifi, well somewhat. It homes fine and has consistent heights. The problem I'm having is with the new Grid compensation. I fire off the deployprobe.g in the bed.g followed by G29 and the machine goes to the first probe point , probes and then moves to the next. The 2nd point gets the following error :
                      G32
                      Error: Z probe already triggered before probing move started
                      This of course is because the probe doesn't get deployed again once triggered by the first probe point.
                      Hopefully someone can tell me where my error in logic is. It seams to me like the deploy is just not being called between points, possible flag to allow that ?
                      Thanks,
                      Jeff
                      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                        Sniffle
                        M558 P4 X0 Y0 Z1 H4 F400 T500
                        http://reprap.org/wiki/G-code#M558:_Set_Z_probe_type
                        On M558 you need to set an H parameter so that the bed(or X axis) will move away from the probe(giving the probe room to allow the pin to fall back into the deployed position) so that it will not error(blinking probe will cause the endstop to be considered triggered always) you may also need to increase your F parameter to increase the speed of movement on the Z axis so that also doesnt cause the probe to error.
                        The probe should not be retracted between probing. It should trigger and drop back down each time. If you deploy the probe manually using M280 with plenty of clearance from the bed and use your finger to push the pin up it should pull away from your finger flash red and then drop back down when operating correctly. the retract probe command should only be done after finishing the probing.
                          InSanity
                          I must be doing something wrong when I deploy the probe. No matter what the pin always gets sucked back up instantly. The probe isn't going into error mode at all, it just never stays deployed after being triggered.
                          This is what I'm doing with the deployprobe.g file. (M401)
                          M280 P3 S10 I1 ;Deploy probe
                          G4 P75 ;Wait 75ms
                          M280 P3 S60 I1 ;Test mode
                          G4 P125 ;Wait 75ms
                          This triggers as expected however it always sucks the probe up the instant it's triggered and doesn't try to drop it. If I don't include the "test mode" it just slams into the bed and then eventually triggers and goes into alarm. The bed doesn't even try to retreat until well into a crash. Even on a home without the test mode it just crashes into the bed.
                          I would have expected the trigger to occur the moment the pin reaches a certain level like it does while in the Test Mode.
                          BTW I'm running a Flashforge Creator Pro with the Duet WiFi , New Steppers, new carriage and the E3D Legends Pack. All new wiring with a 24 pin Molex MicroFit 3.0 on the back so I can swap out carriages. Prints like a champ with an inductive sensor, the IR sensor I just didn't have much consistency with.
                          Jeff
                            InSanity
                            Playing around over here. I changed the deploy to
                            M280 P3 S160 I1 ;Clear any alarm
                            G4 P450 ;Wait 75ms
                            G4 P75 ;Wait 75ms
                            I went from H 3 to H 5 and F 120 to 320, now it just crashes faster and never tried to retreat. The probe still goes into alarm mode. It's as if the trigger is delayed, I don't see this problem if I put the probe in Test Mode. I'm using the Z-Probe into for the trigger, I can't imagine that would matter. I can toss a scope on the pin to see what it's doing I guess.
                            Jeff
                              InSanity
                              Ok I'm starting to think it is a problem with the Z-Probe not responding fast enough for the 50ms pulse. I'm going to try the Z Endstop. The Z-Probe input does have a 10k resistor and a small cap, I can't imagine that would take too long to reach a good logic level. We shall see.
                              Jeff
                                InSanity
                                I meant to say E0 in my last random thought. In any event I'm seeing the exact same behavior. The bed crashes, the trigger is not seen unless I put the probe in test mode. I'm running 1.17a firmware.
                                Jeff
                                  Sniffle
                                  according to the bltouch people, to work with 3.3v logic electronics you only need a 240ohm resistor in line with the 2-wire endstop. that could be where your not gettign a response. I will say that the web browser doesnt always refresh the probe trigger value fast enough for the trigger to show and I also have my z-probe trigger value set obscenely low to something like 25 since the pulse is so short.
                                  G31 X-30 Y35 Z1.1 P25
                                  as to the deploy this is all my macro is(on H3) M280 P3 S10 I1
                                  I clear alarms separately as i feel that is just a safety check.
                                    InSanity
                                    The resistor is in place. It trigger's just fine if I put the probe in test mode. I've tried the Z-Probe input and now E0 input. The web interface does show they trigger with the probe in test mode. The problem is without that test mode during a home (or probe) the bed just crashes and doesn't stop until the probe goes into alarm which forces the trigger. It's still acting as if the Duet Wifi just can't see that short pulse, which I find hard to believe. The logic levels are clearly ok as it's working while the probe is in test mode. I'm only clearing the errors in the deploy for now as I'm tired of doing so manually during this debug phase.
                                    Any ideas ?
                                    Jeff
                                      InSanity
                                      I just love how helpful people are, much thanks.
                                      The problem is my config override still had G31 P500, I changed that to P25 as suggested. It just never crossed my mind to look at this. Sniffle, your a life savor!
                                      Now to switch back to the Z-Probe input.
                                      Thanks,
                                      Jeff
                                        Sniffle
                                        hmm… if you manually deploy the pin, and the press it up with your finger as if ti were probing does it display the trigger in the web interface? the default action in test mode and alarm is to send a constant signal instead of a pulse. When manually testing mine it doesnt always line up with a web interface value refresh but i could occasionally get it to show.
                                          InSanity
                                          Everything is working perfectly now.
                                          I can confirm the BLTouch works perfect with the Z-Probe input as well as E0 or E1. In either case be sure to use the 240 (or 220) ohm resistor from signal to gnd.
                                          I can also confirm you must have a low value for G31 P parameter. I'm now using P1 and it works perfect, P25 is a safe value it would appear.
                                          On a side note and certainly not for everyone I'm using a 47k resistor a 100k resistor and a green LED on the Z-Probe input to act as a zener diode limiting the voltage to around 2.7v even if I go as high as 24v on the Z-Probe. I have two harnesses that I can quickly swap out for all this testing. The 100k resistor acts to pull the signal back down. The 47k is a current limit and the LED is between gnd and signal. I've tested this on a 300 Mhz scope and even trying to cause spikes with 24v I never had anything go above 2.7v. Plus it lights up when triggered 🙂
                                          Jeff
