    2.03 + PanelDue 7i
    Firmware installation
    952
    • kthoma85undefined
      kthoma85
      Phaedrux, I am working on putting a Duet 2 and a Panel 7 together. White screen when connected to Duet works normal when connected via USB. Any suggestions?
        Phaedrux Moderator @kthoma85
        @kthoma85 how have you got it connected?
        • kthoma85undefined
          kthoma85
          The ribbon cable that is connected to the Panel Due.
            Can you test with the 4 pin connector instead?
            • kthoma85undefined
              kthoma85
              What is the 4 pin connector? Do I need to make one?
              • kthoma85undefined
                kthoma85
                So that is what the other cable that came with the panel is for? I can try it later.
                  The 4 pin connector is the preferred method of connection. It's far more robust and less prone to connectivity issues. The cable length can be much greater as well.
                  • nhofundefined
                    nhof
                    You will still need the ribbon cable if you are using the SD card slot on the paneldue, but you only need the 4-wire otherwise.
                    You can also plug both in and it should work fine.
                      Check that you have the ribbon cable connected to the right port on the Duet, which is CONN_SD, not CONN_LCD despite the name.
                        A Former User
                        Shouldn't the firmware on the PanelDue show the interface and not a white screen as long as it has sufficient power regardless of communication with the Duet? -
                        • kthoma85undefined
                          kthoma85
                          I connected the 4wire connector and it is working fine. Now do I connect the ribbon cable to the blue circle or the orange circle?0_1567695079482_Panel Due connection.png
                          nhofundefined 1 Reply Last reply Reply Quote 0
                          • PaulHewundefined
                            PaulHew
                            Unless you need to use the SD card in the PanelDue, i would not.
                            As @Phaedrux mentioned, you can have a longer cable with the 4 pin, the ribbon cable has a length limit.
                            I upload everything from a computer via a network so no need for the PanelDue SD.
                            • nhofundefined
                              nhof @kthoma85
                              @kthoma85 said in 2.03 + PanelDue 7i:
                              The blue one marked "External SD Card" will also power the PanelDue.
                              • kthoma85undefined
                                kthoma85
                                Thank you everybody. I am good to go now.
                                  @bearer said in 2.03 + PanelDue 7i:
                                  Yes, if the ribbon cable is sound and connected to the correct connector on the Duet.
