    Fan1 dont show
    775
    • TPJensenundefined
      TPJensen @Phaedrux
      @phaedrux said in Fan1 dont show:
      Config.g please.
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
      ; Delta Settings
      M665 L440.000 R227 H456.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
      M552 S1
      M550 P"Anycubic Predator" ; Set machine name
      M551 P"" ; Set password
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P3 S0 ; Drive 3 goes forwards
      M92 X80.00 Y80.00 Z80.00 E380.45 ; Set steps per mm
      M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Retraction
      M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P4 H3 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z16.0 ; Set Z probe trigger value, offset and trigger height
      M557 R115 S20 ; Define mesh grid
      G29 S1 ; Load the heightmap
      M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S250 ; Set temperature limit for heater 1 to 240C
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M572 D0 S0.1 ; Pressure Advance
      ;M591 D0 P2 C4 S1 ; Activate filament sensor
      M404 N1.75 ; Set for print monitor
      M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0
      M501 ; Load saved parameters from non-volatile memory
      Config.g please.
        Phaedrux Moderator @TPJensen
        @tpjensen said in Fan1 dont show:
        M106 P0 H-1 controls the Fan0 port and would be for your part cooling fan, which should show up in the DWC as a slider, and be controllable by the slicer in Gcode during a print.
        M106 P1 H1 T45 controls the Fan1 port and should be for your hotend fan, it is configured to turn on automatically when the temperature reaches 45c.
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
          Further, this command attaches the Fan0 port to your tool, which should make it controllable via the tool fan slider in the DWC.
          TPJensenundefined 1 Reply Last reply Reply Quote 0
          • TPJensenundefined
            TPJensen @Phaedrux
            I have 2 part cooler 1 hotend cooler
            Hotend cooler start when hotend is heated and then only 1 part part cooler turns on with the layer I set it to
              If you have 2 part cooling fans, how are the connected to the board?
              • TPJensenundefined
                TPJensen @Phaedrux
                @phaedrux
                They are like this
                Hotend fan on : Fan1
                Part cooler Fan0 : Fan0
                Part cooler Fan1: Fan2
                  Alright, so you need a M106 command for Fan port 2 similar to the one for fan port 0.
                  M106 P2 S0 I0 F500 H-1 ; Set fan 2
                  • TPJensenundefined
                    TPJensen @Phaedrux
                    Do I write that as a extra line ?
                      Yes. Add it below the other 2.
                      TPJensenundefined 2 Replies Last reply Reply Quote 0
                      • TPJensenundefined
                        TPJensen @Phaedrux
                        Done and it worked 😎 So now I will make the print again tommorow
                        Just one thing more how and where do I write M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
                        M929 S0 ; stop logging
                        • TPJensenundefined
                          TPJensen @Phaedrux
                          @phaedrux
                          And thank you so much for your help 🤝 👍
                            You could add the start to config.g and the stop to your slicer end gcode.
                            Though I question if at this point you actually need it. Logging can also have a negative impact on performance due to the overhead. Best not to use it unless you need it.
                            • TPJensenundefined
                              TPJensen @Phaedrux
                              @phaedrux
                              I dont want to have the M929 running expect if it fails again with the hotend stops heating.
                              So it is just to see what happens if I get more fails.
                              • TPJensenundefined
                                TPJensen @Phaedrux
                                @phaedrux
                                Okay update
                                Maybe I have done some wires wrong... Both fans show up in web control and fan0 start on 3 layer like I told it to do i slicer but the other part cooler fan1 dont turn on unless I use the slider in control panel.
                                Another problem is when fans turn on hot temp fall from 240 to about 230-232 with only the fan0 if I turn fan1 on same time I will get Heater 1 fail. Can it be something about the power to the hotend ?
                                When fan0 turn on and I wait 1-2 min. and turn fan1 on slowly temp drops but no fail on hotend and after that temp is constand.
                                  Ah yes there is one more piece to the config missing. We need to add the extra fan to the tool definition.
                                  Should become
                                  M563 P0:2 D0 H1 ; Define tool 0
                                  That should attach fan0 and fan2 to tool 0
                                    To solve the fans cooling the hotend too much you'll have to aim the fans more carefully so they aren't blowing on the heater block.
                                    You can also use a silicone heater block sock to cover it and shield it from the cool air.
                                    And you can also run the PID tuning with the fans running at your regular print speed so that the model can account for the extra cooling of the block.
                                    • TPJensenundefined
                                      TPJensen @Phaedrux
                                      Should become
                                      Super thank you so much, I'am glad your want to help
                                      • TPJensenundefined
                                        TPJensen @Phaedrux
                                        I have made a order now on silicone socks
                                        • TPJensenundefined
                                          TPJensen @Phaedrux
                                          Okay what is PID tunning and how is this done ?
                                            https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
