    Fan1 dont show
    775
      M563 P0 D0 H1 ; Define tool 0
      Further, this command attaches the Fan0 port to your tool, which should make it controllable via the tool fan slider in the DWC.
      TPJensenundefined 1 Reply Last reply Reply Quote 0
      • TPJensenundefined
        TPJensen @Phaedrux
        @phaedrux said in Fan1 dont show:
        I have 2 part cooler 1 hotend cooler
        Hotend cooler start when hotend is heated and then only 1 part part cooler turns on with the layer I set it to
          If you have 2 part cooling fans, how are the connected to the board?
          • TPJensenundefined
            TPJensen @Phaedrux
            @phaedrux
            They are like this
            Hotend fan on : Fan1
            Part cooler Fan0 : Fan0
            Part cooler Fan1: Fan2
              M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              Alright, so you need a M106 command for Fan port 2 similar to the one for fan port 0.
              M106 P2 S0 I0 F500 H-1 ; Set fan 2
              • TPJensenundefined
                TPJensen @Phaedrux
                Do I write that as a extra line ?
                  Phaedrux Moderator @TPJensen
                  Yes. Add it below the other 2.
                  TPJensenundefined 2 Replies Last reply Reply Quote 0
                  • TPJensenundefined
                    TPJensen @Phaedrux
                    Done and it worked 😎 So now I will make the print again tommorow
                    Just one thing more how and where do I write M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
                    M929 S0 ; stop logging
                    • TPJensenundefined
                      TPJensen @Phaedrux
                      @phaedrux
                      And thank you so much for your help 🤝 👍
                        @tpjensen said in Fan1 dont show:
                        You could add the start to config.g and the stop to your slicer end gcode.
                        Though I question if at this point you actually need it. Logging can also have a negative impact on performance due to the overhead. Best not to use it unless you need it.
                        • TPJensenundefined
                          TPJensen @Phaedrux
                          @phaedrux
                          I dont want to have the M929 running expect if it fails again with the hotend stops heating.
                          So it is just to see what happens if I get more fails.
                          • TPJensenundefined
                            TPJensen @Phaedrux
                            @phaedrux
                            Okay update
                            Maybe I have done some wires wrong... Both fans show up in web control and fan0 start on 3 layer like I told it to do i slicer but the other part cooler fan1 dont turn on unless I use the slider in control panel.
                            Another problem is when fans turn on hot temp fall from 240 to about 230-232 with only the fan0 if I turn fan1 on same time I will get Heater 1 fail. Can it be something about the power to the hotend ?
                            When fan0 turn on and I wait 1-2 min. and turn fan1 on slowly temp drops but no fail on hotend and after that temp is constand.
                              Ah yes there is one more piece to the config missing. We need to add the extra fan to the tool definition.
                              Should become
                              M563 P0:2 D0 H1 ; Define tool 0
                              That should attach fan0 and fan2 to tool 0
                                To solve the fans cooling the hotend too much you'll have to aim the fans more carefully so they aren't blowing on the heater block.
                                You can also use a silicone heater block sock to cover it and shield it from the cool air.
                                And you can also run the PID tuning with the fans running at your regular print speed so that the model can account for the extra cooling of the block.
                                • TPJensenundefined
                                  TPJensen @Phaedrux
                                  Should become
                                  Super thank you so much, I'am glad your want to help
                                  • TPJensenundefined
                                    TPJensen @Phaedrux
                                    I have made a order now on silicone socks
                                    • TPJensenundefined
                                      TPJensen @Phaedrux
                                      Okay what is PID tunning and how is this done ?
                                        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                                          I think I made a mistake with the tool definition I provided above.
                                          M563 P0:2 D0 H1 ; Define tool 0 is incorrect.
                                          I should have said M563 P0 D0 H1 F0:2 ; Define tool 0
                                          • TPJensenundefined
                                            TPJensen @Phaedrux
                                            hehe okay I was just about to write that it did not work, I wil try that setting when then print is done 🤝 👍
