    Multi Colour Printing without using wipe or prime towers
    Example setups and prints
    9
    48
    11.2k
    • Zesty_Lykleundefined
      Zesty_Lykle
      Clever idea Deckingman, I like it.
      One more complication I noticed. Different filaments need different purge lengths. For instance when I am switching from black to white, I need to purge a hell of a lot more than when going from green to blue, for instance.
      No idea if that is the case with all hot ends, not having a Diamond I can't test it.
      Also, how is this with different types of filaments? Is ABS easier or worse than PLA, for instance.
      Lykle
      Design, make and enjoy life
      Co Creator of the Zesty Nimble
        deckingman
        Hi Lykle (yasoo file mou)
        No problem with different coloured filaments on the Diamond - can't really see why different colours of the same filament would need different purge lengths. I suspect the purge length you need for Black to White is correct and using less with Green/Blue probably means that they aren't fully purged but you can get away with it because a bit of Blue mixed in with Green probably doesn't show up. Funnily enough, I've just finished a door sign for my Hairdresser (well it got me a free haircut), not Black and White but Black and Silver (that's what the filament is called but it's light grey in fact). I used the same purge setting as the Union Jack. It's not perfect - there is a bit of Black round one of the screw holes which shouldn't be there) but it's not far out. Here is a link https://youtu.be/naiLL9qYeTE.
        Maybe something weird happens with different dyes but I've not yet come across that problem. Having said that, I have only done limited testing so far and it's early days.
        Can't comment on filaments other than PLA. I can't think of any logical reason why the same method wouldn't work though.
          Zesty_Lykle
          Yasou!
          OK, so the Diamond head is definitely a different beast than my lowly V6 lite.
          Good to know. I should try and upgrade but way to busy at the moment.
          If you want to try out different filaments that feel completely saturated with colour, you should try nGen. It feels as if you are printing colour particles instead of plastic. Their white even gives the impression of being "chalky". It isn't but that is what it feels like.
          (btw, was thinking of designing a very compact 3 filament Nimble, good idea?)
          Lykle
            deckingman
            Yasou Lykle,
            Purging during tool change with a mixing hot end is a lot different to purging out a single filament to be replaced with another. I think that's maybe led to a bit of misunderstanding. For sure, when you want to change one filament for another it takes quite a lot to purge all trace of the old filament out of the hot end. But when you switch from one loaded filament to another, you only need to purge the small bit of filament that is in the mixing chamber and from the mixing chamber to the nozzle tip. I was quite surprised myself when I started testing on how little this actually is. For example, when loading a new filament I'll extrude 50mm or more before the new colour is complete;y clean of all traces of the old. However, when switching between one loaded filament and another, it takes only around 2.5mm. From observation, the "transition" between one filament and the other is I'd guess only about 10% of that so around 0.25mm which in most cases is hardly noticeable. Of course, other "multi input" hot ends might have larger mixing chambers and need more purging, so there may still be a need for some sort of small sacrificial "tower" if there is a large transition period between filament changes. The Diamond doesn't really have much of a mixing chamber - it's about 2mm long. This is both an advantage and a disadvantage in that the filament doesn't actually get mixed but rather, comes out like stripey toothpaste.
            Not sure how a 3 filament nimble would work. You need to drive each filament independently and feed each one to a different heat sink/input on the hot end.
              Zesty_Lykle
              Clear.
              Wonder if changing the position of the filament feed holes will change the stripey aspect. Doubt it. Will probably need a screw in nozzle option to make real mixing an option. Looking at the corkscrew shapes they force plastics through to mix properly, it might be a bit too big.
              3 filament Nimble. Just a small block that holds 3 complete Nimble mechanisms. But the idea is a bit silly as it will be just 3 extruders coupled to the hot ends with bowden tubes. Only advantage is that the extruder block is very small. OK enough about this.
              One more thing on the color changing. Just a comment on the cleverness of the people here.
              1 you thought of it and tried it.
              2 David and Tony took one look and realised what you are doing.
              clever.
              Lykle
                deckingman
                @Zesty_Lykle:
                Clear.
                clever.
                Thanks - I'll take that as a compliment. As an ex automotive engineer, self taught in writing code and everything else, currently scratching a living by cutting and screwing bits of wood together, and too many years the wrong side of 60, I need all the encouragement I can get.
                • Dougal1957undefined
                  Dougal1957
                  I have just ordered a Diamond Hotend for the CoreXY Build that I intend to resurrect after Xmas so may well be chasing you for configs etc when the time comes
                    deckingman
                    @Dougal1957:
                    Any time Doug - you know my email address. I've got my machine pretty well dialled in. Of course, if there is info you need that might benefit others, then post here and I'll reply here.
                      deckingman
                      So as promised, herewith a link to the new blog that I have set up, in which I have created a post giving full details of my technique. The information should all be clear but if you have any questions, feel free to comment on the blog and I'll do what I can to help. https://somei3deas.wordpress.com/blog/
                      Please bear in mind that I only set the site up a couple of days ago and I've gone with the free WordPress plan which means I am very limited in what I can do with the design and layout. Also, apart from a brief introductory post, this is the first post I have ever made so I have much to learn.
                      Be warned that I'm not a programmer and if you use the Python Script which I have linked to, and it crashes your PC, don't blame me. Having said that, it works fine for me.
                      I give this information freely in the hope that others may benefit from my endeavours. If you find it useful, then a word of thanks or attribution would make an old man very happy.
                      • InSanityundefined
                        InSanity
                        It would be cool to have some kind of color/transparency sensor that could determine if the filament has reached the correct spot in the tool chain. Not sure what good that would actually do, but sounds fun.
                        Jeff
                        Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                          deckingman
                          @(In)Sanity:
                          Jeff
                          I have no idea what that means or how it could help. Each of the filaments are loaded into the hot end as far as they can go which is the point where they all come together in the "mixing chamber". They have to be. If there is any gap, filament from one of the other inputs will be forced back up into it. So the distance from the end of the filament where it enters the hot end, to the nozzle tip is a fixed amount which never changes. Why would you need any sort of sensor?
                          • InSanityundefined
                            InSanity
                            So picture a sensor that can detect if the nozzle has reached a purity level and then can skip steps on the priming tower to not waste as much plastic, The next prime would just bridge if needed. This could allow variable priming. Such a sensor would be incredibly hard to accomplish short of a focused camera, or passing light through the filament. I have a Cyclops myself and so far I'm happy with it.
                            Yah I know this has nothing to do with your approach.
                            Jeff
                              deckingman
                              After a bit more testing, I've made a bit of a discovery. I'm not 100% sure but it seems that the required "purge amount" needed to find the optimum tool change position is inconsistent, and that this inconsistency may be related to print speed. I've put a bit more detail in my blog https://somei3deas.wordpress.com/2017/01/16/update-to-blog-6th-jan-printing-without-wipe-and-prime-towers/
                                deckingman
                                This is a copy and paste of something that I have just posted on the reprap forums.
                                If my theory is right, then if the speed of filament through the extruder is constant the amount needed to purge the hot end will be constant. What I think is happening is that the melt zone effectively expands and contracts inversely proportional to speed of filament through the extruder, so the amount of filament needed to purge also changes. There is probably a time element in this as well. This is something that I had observed at the start of every print where there seemed to be "bleeding" of colours after printing the perimeters to purge each tool and then starting the print proper. i.e the first tool change or two. I thought it was an error in my script but I'm now leaning towards the theory that it is due to the long heat soak that the hot end is subject to while it is warming up which effectively increases the melt zone. This can easily be overcome buy increasing the purge amount for the first tool change or two but I need to do more testing to determine how much by.
                                The difficulty arises when there are significant changes to print speed, for example the fist layer is usually printed more slowly so more filament will need to be purged than for other layers. Having said that, it won't be a huge problem if some of the inner layers are slightly out, as long as the outer perimeters and visible surfaces are correct. What is obvious though is that if the "purge amount" is optimised for an object printed at 80mm/sec, then it won't work for another object printed at 40mm/sec. It is possible to get the correct purge amount for any object by trial and error but it would be nice to have an algorithm that calculates it automatically. So, I need to do a lot more testing to determine the relationship between extruder speed and purge amount required.
                                The thing that will really balls this up is that if the user changes the print speed after the script has been run and during a print. In which case, the purge amount needs to be dynamically variable in "real time" depending on extrusion speed and that could only be achieved through firmware and not by a static "pre-print" script. (are you listening dc42?) winking smiley
                                In the end, it may be that a small wipe of prime "tower" or mechanism is still required but it won't need to be anything like as large.
                                  T3P3Tony administrators
                                  Sounds like you are really getting into the details. My idea for working this out is to print a pattern with varyingly long elements, colour changes at a constant point at the start of each element of the pattern. That way the user can say that leg (say) 5 of the pattern had the colour change happen exactly at the corner. Each leg would correspond to a specific colour change purge length.
                                  An array of these patterns could then be printed for each colour combination desired, and speed desired, and the script would take these user inputs to inform how far in advance to time the change.
                                  I can draw a picture if that helps
                                    Ian, I think the change in position of the purge zone is related to pressure advance. Suppose you are doing a long straight printing move at high speed and the filament needs to be switched in the middle of it because a colour change is required some time later. With pressure advance enabled, the old filament will be pushed more gently just before the change, or even retracted, while the new filament will be fed in more vigorously at the start. If you don't use pressure advance then the changeover will be delayed because of the elasticity of the filament in the Bowden tube.
                                    So you could try increasing pressure advance, and see if you can find a value that gives you a constant purge length. The right amount of pressure advance should also make the colour change sharper.
                                      deckingman
                                      No worries Tony. I have a test piece that works very well and it's similar to what you had in mind.
                                      It's essentially two rectangles inside a larger rectangle. Or put another way, one large rectangle (more or less square) with two rectangular (oblong) cut outs which is one colour, then each cut out is filled with a rectangle of a different colour. This give 3 colours and lots of changes between the various colour combinations within the same layer. When it is printed, it always end up filling in a small corner of a rectangle before starting the next rectangle so it's easy to spot if the purge is too much or too little. It's how I tuned the purge before printing the Union Jack.
                                      All I need to do is run the script on the native gcode for that object (don't even have to slice it again) with "purge amounts" from say 2mm to 10 mm in 0.5 mm increments. That'll give me 20 or so files with different purge settings (tool change positions) but otherwise the same. Then if I print the object at say half speed using a different file each time, by iteration I should find the optimum purge setting for that speed. Repeat for other speeds and I'll end up with a matrix of speed/purge settings. Hopefully, I'll find a linear relationship between speed and purge which should be relatively easy to compensate for. The script would then (probably) interrogate the gcode file to find what the extrusion speed is prior to the tool change, then adjust the "purge amount needed" accordingly. (Not sure if I explained that well but hopefully you get the idea).
                                      Cheers
                                        deckingman
                                        @dc42:
                                        That's very good point David. From what I have observed, I don't think it's the whole story though it could well play a part. I definitely need more purge at the start of a print, when it changes from doing the outer perimeters to doing the perimeter of the print proper, which is essentially the same moves just inset a bit and then after that, the purge seems to work OK. I put this down to the extended heat soak with no filament moving through the nozzle during the warm up phase.
                                        On the other hand, filaments that aren't being used will be sitting in the melt zone a long time, so the effective size of the melt zone for those filaments should be fairly constant regardless of print speed (because those filaments are static), which means that pressure advance may indeed be an important factor. I have to say that when the purge amount didn't seem to be enough, I was printing at a slow speed. What I hadn't considered (until now) is that the reason I was printing so slowly was because the object was mostly thinnish sections with very short print moves. I could well have put 2 and 2 together and made 5.
                                        Lots more experimenting and testing to do - roll on retirement when I will have more time….....
                                        P.S. thanks for the tips guys.
                                          deckingman
                                          A further update on this if anyone is interested (judging from the lack of visitors to my blog and the complete absence of any comments, likes or followers, I'd say that not many people are interested).
                                          Anyway, I've done some testing and the issue that I had noticed isn't speed related. Full details on my blog here https://somei3deas.wordpress.com/2017/01/16/update-to-blog-6th-jan-printing-without-wipe-and-prime-towers/
                                          If nothing else, the last picture on that post shows a close up of the technique as good as it'll ever get, due to the transition period between colour changes. I don't think it's bad but whether it's acceptable is up to each individual to decide.
                                            "reasonable amount of filament extruded between tool changes but cannot cope with tool changes that are too close together."
                                            That makes complete sense, after all if the previous change has not finished purging then another change will end up with a mix between the new colour and the purge (which is part way between colours), or am i not getting this right?
