Problem with the screw terminal from the hotend connection
Good evening,
Thank you very much for the reception. I am new here and come from Germany. My Duet Ethernet is built into a Hypercube Evolution.
I have a problem with my Duet Ethernet board. When changing from the Hotend I did not get the cable out of the terminal at the Hotend connection, I had to cut off the cable.
I could unsolder the connection without problems, however I do not find in the wiki unfortunately the designation and the grid measure of it not.Does anyone happen to have a relationship from the terminal for me?
usually headers are 2.54, 3.81 or 5.08mm (0.1", 0.15" and 0.2") and I'm pretty sure its not 2.54 and 5.08mm
kicad sources are available here https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
edit: i used these on my duet 2 maestro https://uk.farnell.com/phoenix-contact/mc-1-5-2-g-3-81/header-right-angle-3-81mm-2way/dp/3704725?MER=sy-me-pd-mi-acce
Do I see that correctly that you have solved it with a plug connection? I also have something like this on my ethernet.
I replaced the screw terminals with pluggable terminals yeah, but you should be able to fit any 3.81mm terminal.
I find pluggable terminals better are screw terminals. The cable then only once screwed
More convenient yeah, but not always possible to find reasonably priced pluggable connectors with sufficient current rating; but these aren't too pricy and good for 8A.
On Duet 3 we have switched to JST VH connectors. We'll probably do that on Duet 2 when we do the next design refresh, if our OEMs are happy to change their wiring looms.
Do you have a picture of the new connections you used in Duet 3? And what is the name of those currently installed for the hotends.
They're a bit "oddball" at 3.96mm pitch, so they won't fit the Duet 2. But just google JST VH, plenty of pics.
(Edit: Pins are also thicker) -
Correct, I've just verified that you can't get a JST VH connector into the holes for the hot end terminal block in a Duet 2 PCB, because the pins are too large and the hole separation is wrong.
Most 2-way 3.81mm pitch terminal blocks should fit the Duet 2.
Someone recently mentioned wago spring Drogen connectors Here, maybe they're a nice idea for a home conversion ...
