    Problem with the screw terminal from the hotend connection
    498
      A Former User
      usually headers are 2.54, 3.81 or 5.08mm (0.1", 0.15" and 0.2") and I'm pretty sure its not 2.54 and 5.08mm
      kicad sources are available here https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
      edit: i used these on my duet 2 maestro https://uk.farnell.com/phoenix-contact/mc-1-5-2-g-3-81/header-right-angle-3-81mm-2way/dp/3704725?MER=sy-me-pd-mi-acce
      • Patrick_487undefined
        Patrick_487
        Do I see that correctly that you have solved it with a plug connection? I also have something like this on my ethernet.
          A Former User
          I replaced the screw terminals with pluggable terminals yeah, but you should be able to fit any 3.81mm terminal.
            Patrick_487
            I find pluggable terminals better are screw terminals. The cable then only once screwed
              A Former User
              More convenient yeah, but not always possible to find reasonably priced pluggable connectors with sufficient current rating; but these aren't too pricy and good for 8A.
                On Duet 3 we have switched to JST VH connectors. We'll probably do that on Duet 2 when we do the next design refresh, if our OEMs are happy to change their wiring looms.
                  Patrick_487
                  Do you have a picture of the new connections you used in Duet 3? And what is the name of those currently installed for the hotends.
                    A Former User
                    They're a bit "oddball" at 3.96mm pitch, so they won't fit the Duet 2. But just google JST VH, plenty of pics.
                    (Edit: Pins are also thicker)
                      Correct, I've just verified that you can't get a JST VH connector into the holes for the hot end terminal block in a Duet 2 PCB, because the pins are too large and the hole separation is wrong.
                      Most 2-way 3.81mm pitch terminal blocks should fit the Duet 2.
                      • oliofundefined
                        oliof
                        Someone recently mentioned wago spring Drogen connectors Here, maybe they're a nice idea for a home conversion ...
