SD card slot failed in Duet wifi
@bearer One question, if the warranty has already passed, what options do I have to repair the card? I do not know what to do
EU consumers usually have good protection from vendors beyond manufacturers warranty, but I'm not familiar with your country, your vendor will be able to answer you.
If all else fails, and you're certain the problem is the sd-card reader on the board, then I'd take it to a cell phone repair shop and ask them to replace the sd-card socket. However your the second picture you posted does say the card is detected, but its still possible other pins of the socket is damaged. Does the problem persist if you disconnect any other accessories (while powered off)?
@bearer said in SD card slot failed in Duet wifi:
Ahh i missed that.
@GOYO i don't think is the card detect pin then, although that is by far the most common issue of the SD card has been working fine up until now. and normally over many 1000s of insert/removes.
@t3p3tony hello, I have not removed the card since I mounted it last year, this week I started not to connect and started looking at the github and I noticed by other users who also had that problem, I did all the checks that Mr. DC42 explained to another user and I realized that I had the same problem, as I say I have not released the SD since last year that the mount in the duet
@bearer I had never removed the card until now that I had a connection error, I have a cr10 and the electronic box has been closed until now
@t3p3tony
I've been like this for 3 days
@goyo please send a good picture of the SD card socket showing how it is soldered on, and also a picture around the processor. Also i note your MC temp of 40 degrees, thats probably not calibrated, does it feel hot to the touch?
This post is deleted! -
the processor is not hot
