    Heater Fault
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      So running a print on my Railcore and has been fine for 2 hours.
      It is now paused and displayed this error.
      09/09/2019, 08:11:57: : Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
      Resume state saved
      Have no idea what has caused this so any advice would be appreciated.
      E3D V6 hotend.
      Config as below
      0_1568019011608_config(5).g
      Regards,
      Paul
      • PaulHewundefined
        PaulHew
        Also, I cleared the fault, clicked resume and it did not bother to wait for the hotend to heat up, instead started printing or trying to.
        Is this correct?
        09/09/2019, 09:51:48: : Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        09/09/2019, 09:51:52: : Printing paused at X241.1 Y120.3 Z1.6
        09/09/2019, 09:53:42: : Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.0°C/sec
        So, I allowed to heat up again, it printed 3 lines, then errored again.
        09/09/2019, 09:57:50: : Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
        09/09/2019, 09:57:52: : Printing paused at X213.1 Y133.6 Z1.6
        Not sure what to do or what the problem is. 😞
          T3P3Tony administrators @PaulHew
          @paulhew can you repeat the heater fault not during a print:
          • Moving the gantry/testing the limits of the wire movement
          • Fan settings that may be overly cooling the hotend instead of the print.
          • PaulHewundefined
            PaulHew
            Thanks Tony.
            Issue was, I forgot to put my silicone sock back on to the heater block Doh! 🤦
            First big print and getting used to the new printer and using Prusa Slicer instead of Cura
            The duct and fan for part cooling is tooo good!
            Never had these problems on my Ender3 !!! LOL
            Thank you and sorry.
            P.
              glad its sorted!
                droftarts administrators
                @PaulHew said in Heater Fault:
                There shouldn't be any problem using Cura with Duet, if you prefer it. I tend to use Cura for convenience/ease of use/generally good quality gcode. Are you having particular problems?
